Thread Closed
calculus based physics Vs. algebra based physics
Share Thread Thread Tools
Feb18-08, 08:52 AM   #1
in my high school physics class we are doing algebra baced physics but i have heard of calculus based physics and i wanted to know the differences between them and the different Applications that they have.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Front-row seats to climate change
>> Attacking MRSA with metals from antibacterial clays
>> New formula invented for microscope viewing, substitutes for federally controlled drug
Feb18-08, 12:14 PM   #2
Algebra based physics is learning physics that pretty much only uses algebra (some trig). Calculus based physics uses calculus.
So basically your class is an intro to calc based physics. You learn all the concepts of physics without messing around with all the math. If you don't know any calculus, then it will be hard to explain the benefits of it. But if you've taken calculus, then it should be pretty obvious what it can be used for.
Let me try to explain anyway, because that didn't really answer your question. Calculus lets you "add up" small contributions to get a total. For example, you have your equation for how long an object stays in the air when you throw it, right? There should be a variable there that is squared. In one of those formulas, anyway. So the only way you can do that right now is to use the formula. With calculus, you start with something more basic, and you can actually derive the formula.
Okay, that was a bad explanation. Umm... just wait until someone gives you a better one. :(
Feb18-08, 12:28 PM   #3
Recognitions:
Gold Membership Gold Member
Homework Helper Homework Help
Retired Staff Staff Emeritus
Adding calculus to Physics I, at least at the level of Halliday, Resnick, and Walker, results in hardly any new physics being taught. For instance in algebra based physics, you take the following formula as given:
[tex]x(t)=x_0+v_0t+\frac{1}{2}at^2[/tex]
In calc based physics you derive that formula by integrating [itex]\frac{d^2x}{dt^2}=a[/itex] twice. Kinematics with nonconstant acceleration is relegated to the Exercises. What really makes calc based Physics I different from algebra based Physics I is not the calculus, but the use of the dot and cross products (most algebra based physics courses don't teach this).
Now when you get to Physics II, the calculus makes a huge difference, because you can finally learn Maxwell's equations.
Feb18-08, 12:40 PM   #4
I suppose for physics I, calculus makes little difference, as what is derived by calc, can often be derived alebraicly too, but calc is probably simpler. Without calculus you can't go very far in physics. Or just about anything that uses math- business, engineering, social sciences etc.
Feb18-08, 12:47 PM   #5
I've been told that algebra based physics is an ugly mess whereas calc based physics is nice, elegant, and actually easier. This was told to me by my precalc teacher.
Feb18-08, 01:19 PM   #6
Not really. Neither of them are really a mess. Algebra-based physics is actually simplified from calc physics, but calc physics has the advantage of using more elegant notation.
Feb18-08, 01:23 PM   #7
in algebra based phys, you let the partition of finite difference and summation goes to 0, you will get a calculus based physics. Nothing else more than that
Feb18-08, 02:30 PM   #8
D H
Mentor
Quote by Tom Mattson View Post
I just dusted off my very old Halliday and Resnick, copyright 1966, and they certainly went well beyond algebra-based physics. Here are a few topics in which calculus played an integral role: Work as a line integral; the rocket equation; coupled, damped, and forced harmonic oscillators; simple fluid dynamics and thermodynamics. Moreover, many topics which are presented as givens in pre-calculus physics are derived in that ancient version of Halliday and Resnick; e.g., Kepler's laws of motion. Has the Halliday, Resnick, and Walker text dumbed things down since I went to school back in the stone age?
thharrimw, This enhancement of details is how physics education progresses. You will learn some simple aspect of a problem at one level, such as the behavior of a particle subject to a constant acceleration. Calculus-based physics throws out all those seemingly unrelated formulae you learned in algebra-based physics, replacing them with a smaller set of more abstract and more mathematically advanced equations. Junior level classical dynamics throws that simple freshman-based physics out the window. Graduate level courses throw out the simple junior level stuff.
I have not yet touched on electricity, or quantum mechanics, or gravitation. The same processes occur there that occur with classical dynamics. Each step up you are learning some new physics. You are also relearning the physics you already know, but with the added twist of mathematical techniques that you presumably did not have knowledgeof the first time around.
Feb18-08, 02:48 PM   #9
Recognitions:
D H,
Yes, Halliday and Resnick & Co. have watered their book down considerably since the old days. I once saw an early edition of their book that showed a derivation of the differential form of Maxwell's equations from the integral form. Now, only the integral form remains and the differential form isn't even mentioned.
This is presented, but in the exercises students are only asked to integrate along straight line segments. And for most exercises, no integration is required at all.
This is presented, but students don't actually have to do any calculus in the exercises.
The differential equations for these systems are presented, as well as their solutions. But they don't solve the equation in the book, and the students are never asked to do it. A curious student could plug the given solutions back into the diff eq to verify that it is indeed a correct solution, but this is never asked of the student.
The syllabus at the school where I taught as a grad student excluded these topics, as full courses in each subject were offered. So I never went through these chapters of H&R.
Feb19-08, 08:14 AM   #10
ok all of this has made me more confused,
What is derivation?
What is a differential form?
and
What is a integral form?
also in calc baced physics can you use these differntial and integral things and do more then you could if you used algebra equations?
Feb19-08, 08:33 AM   #11
D H
Mentor
Quote by thharrimw View Post
What is derivation?
In this context, derivation is "a sequence of statements (as in logic or mathematics) showing that a result is a necessary consequence of previously accepted statements" (from http://www.merriam-webster.com/dictionary/derivation).
Algebra-based physics is chock full of a bunch of disparate, ad-hoc formulae that must be memorized. Many of these ad-hoc formulae can be derived from a small set of seemingly simple equations. In algebra-based physics, the expression [itex]x=x_0 + v_0 t + 1/2at^2[/itex] is one of those ad-hoc forumulae. It can be derived from [itex]d^2x/dt^2 = a[/itex], which in turn is a consequence of Newton's second law.
Another example is Kepler's laws. You probably had to memorize these as equations that just popped out of the blue in Kepler's mind. Kepler's laws are the result of deeper physics and more advanced math.
and
This is a differential form: [itex]\nabla \cdot \mathbf{B} = 0[/itex]. The corresponding integral form is [itex]\oint_S \mathbf{B} \cdot d\mathbf{S} = 0[/itex]. In English, there are no magnetic monopoles. If you haven't had calculus, that looks like gibberish.
Yes. That is one of the reasons we use it.
Feb19-08, 09:10 AM   #12
I haven't had calc but I get the concept now even though I have no idea how to do the math!Are there rules for differential and integral forms like there are in algebra? If so what are they?
Feb19-08, 09:31 AM   #13
if it's a toss up between a decent teacher teaching the calc based, and a crappy teacher teaching the algebra based, take the calc based.
to make a long story short, during my freshman year, I took the algebra based physics course, struggled and got a C. Then I toook the calc based physics, didn't struggle, and got a B. I was taking calc at the same time as physics, and didn't get held up by the calc...
guess that's it....best of luck with you decision.
Feb19-08, 09:32 AM   #14
Recognitions:
Why do educators still teach algebra-based physics when they could simply teach the calculus mathematics first, then afterwards go straight to calculus-based physics? It saves the trouble of having to memorise equations when doing algebra-based physics.
Feb19-08, 09:38 AM   #15
Recognitions:
The "rules" for differential forms come from the divergence theorem and Stokes' theorem.
[tex]\int_V {\nabla \cdot \vec{F}} = \int_{\partial V} {\vec{F} \cdot d\vec{S}}[/tex]
and
[tex]\int_S {\nabla \times \vec{F}} = \int_{\partial S} {\vec{F} \cdot d\vec{l}}[/tex]
Which allow you to switch from differential and integral forms. Of course, you'll have no idea what this means.
Feb19-08, 09:42 AM   #16
Recognitions:
Quote by Defennnder View Post
Some curricula don't require calculus-based physics, let alone requiring calculus.
Feb19-08, 10:06 AM   #17
Recognitions:
Curriculum for high school or college? Calculus is an essential mathematical tool for just about every scientific, engineering field. And why don't require it when just about every student in high school is going to have to learn calculus anyway, unless they've chosen to major in the arts and literature?
Thread Closed
Thread Tools
Similar Threads for: calculus based physics Vs. algebra based physics
Thread Forum Replies
algebra based -> calculus based physics Academic Guidance 13
calculus based physics Academic Guidance 2
calculus based physics Academic Guidance 8
calculus based physics course Academic Guidance 1
calculus based elementary physics Introductory Physics Homework 2
