Why Can't You Add Fields Component-Wise for a Dipole?
The discussion centers on calculating the electric field produced by a dipole consisting of two charged particles, -q and q, each with a charge of 3.20 x 10-19C, positioned 3 m from the y-axis. The user initially attempted to compute the electric field at point P (y=4 m) by summing the components separately, which led to an incorrect result due to using the wrong distance in calculations. Ultimately, the user resolved the issue by correctly applying the dipole equation and adjusting the distance used in their calculations.
  • Understanding of electric fields and dipole moments
  • Familiarity with Coulomb's Law and its application
  • Knowledge of vector addition in physics
  • Basic calculus for understanding field equations
  • Study the derivation and application of the dipole equation in electrostatics
  • Learn about vector components in electric field calculations
  • Explore the implications of distance in electric field strength
  • Investigate common mistakes in electric field calculations and how to avoid them
Students studying electromagnetism, physics educators, and anyone interested in mastering electric field calculations involving dipoles.
Saladsamurai
[SOLVED] Electric Field due to a Dipole
The figure shows two charged particles on an x axis: -q=[itex]-3.20(10^{-19})C[/itex] and q=q=[itex]3.20(10^{-19})C[/itex]. They are both a horizontal distance of 3 m from the y axis. What are the magnitude and direction of the net electric field produced at P at y=4 m?
Okay. So I know I can use the Dipole equation for this, but I had originally tried placing a test charge at P and adding the fields component wise.
I got the wrong answer and I was just wondering why you cannot take this approach?
This is what I had tried:
[tex]E_{px}=\sum E_x=k[\frac{-|q_1|-|q_2|}{d^2}](\frac{3}{5})=-3.836(10^{-10})[/tex]
And
[tex]E_{py}=\sum E_y=k[\frac{-|q_1|+|q_2|}{d^2}](\frac{4}{5})=0[/tex]
Nevermind. This works! I was using the wrong d!
  • · Replies 25 ·
