2 vector problems(am i doing them right)
  • Context: Undergrad
  • Thread starter Thread starter ilikephysics
    Vector
The discussion revolves around two vector problems involving the representation of vectors in polar coordinates and the calculation of gradients. Participants explore the conversion of a vector from Cartesian to polar coordinates and the implications of starting points for vectors.
  • One participant presents a vector V=2i+3j at the point (1,2) and attempts to convert it to polar coordinates, suggesting the result is 2 cos 2 i + 3 sin 2 j.
  • Another participant clarifies that in polar coordinates, r is the distance from the origin to the endpoint of the vector, and theta is the angle from the x-axis to the line connecting the origin to the endpoint.
  • There is a question about how to express the endpoint (3,5) of the vector starting from (1,2) and how to represent the polar coordinates as a vector.
  • A later reply confirms the understanding that a vector starting from a point means its endpoint is calculated by adding the vector components to the coordinates of the starting point.
  • Participants discuss the conversion of the gradient of a function to polar coordinates, with one participant questioning their approach to this conversion.
Participants express different interpretations of how to convert vectors from Cartesian to polar coordinates and the implications of starting points for vectors. There is no consensus on the correct approach to these conversions, and some participants seek clarification on specific calculations.
Some participants express uncertainty regarding the conversion process and the representation of vectors in polar coordinates. There are unresolved questions about the correct application of formulas for converting between coordinate systems.
ilikephysics
1. Write out the vector V=2i+3j at the point (x,y) = (1,2) in terms of the unit vectors in plane polar coordinates. Do this again for the same vector at the origin. Are your results different? Why?
Answer:
From my notes, I see that x,y = (r, theta) and x=r cos theta, y=r sin theta.
So, for (1,2) the vector is 2 cos 2 i + 3 sin 2 j
At the origin, (0,0), the vector is zero. Am I on the right track?
2.Find the gradient of the function phi(x,y)=2x^2y at the point (x,y)=(1,2), in plane polar coordinates.
Answer:
The gradient is 4xyi+2x^2j. At (1,2) it's 8i+2j. How would I put it in plane polar cooridnates? Would the answer be (8 cos 2) i + (2 sin 2) j?
Thanks.
r means the distance from origin to the end point of the vector. Theta is the angle between x-axis ant the straight line from (0,0) to the end point. So, when you have a notation in polar coordinates (r, theta) you can convert it to cartesian calculating x=rcos(theta) and y=rsin(theta). But when you turn from cartesian to polar, it will go like this: r=sqrt(x^2+y^2) and theta = arctan(x/y)
The first problem goes like this: vector 2i+3j at the point (1,2) (if i understood right)has its end point at (3,5), so r=sqrt(34) and theta=arctan(3/5).
The same vector at the origin has its end point at (2,3)
question
How did you get the endpoint (3,5)? How would I right the sqrt(34) and arctan(3/5) as a vector? Did I do #2 right?
if I understand right "a vector at a point" means that we take the point and let the vector start from it. So if a vector 2i + 3j starts from point (1,2), thet its endpoint will be at (1+2,2+3)=(3,5).I made a picture, so you will understand what i mean. When you write a vector in polar coordinates you write just (r, theta), where in your case r=sqrt(34)~5.83 and theta=arctan(3/5)=0.54, so in polar coordinates : (sqrt(34), arctan(3/5))~(5.83, 0.54).
#2 you should do the same way. It's right until you convert cartesian to polar.
  • · Replies 29 ·
