Source of Energy for the Rotation of Earth
The discussion centers on the factors influencing the Earth's rotation, including whether it could stop and start again, the mechanisms behind its current rotation, and the potential for harnessing this rotation as an energy source. Participants explore theoretical and conceptual aspects of planetary rotation, angular momentum, and gravitational effects.
  • Some participants suggest that the Earth’s rotation is primarily a result of its initial conditions and the conservation of angular momentum in a frictionless environment.
  • Others propose that tidal effects and interactions with the Sun's magnetic field contribute to the slowing of Earth's rotation by transferring angular momentum.
  • A participant raises the idea of harnessing the Earth's rotation as an energy source, referencing pendulums that appear to swing indefinitely, though this is challenged by others who clarify the mechanics behind such pendulums.
  • There is mention of the impact that created the Moon as a significant factor in the Earth's current rotation rate, with some participants emphasizing the angular momentum from the Earth's formation.
  • One participant questions the feasibility of a non-spinning object in space, while another discusses the rotational characteristics of Mars in relation to its lack of a significant moon.
Participants express various viewpoints on the mechanisms of Earth's rotation and its potential to stop and start again. There is no consensus on the exact contributions of different factors, and multiple competing views remain throughout the discussion.
Some claims rely on assumptions about the nature of angular momentum and gravitational effects, while others reference theoretical concepts like frame dragging without empirical evidence. The discussion does not resolve the complexities of these interactions.
This discussion may be of interest to those exploring planetary science, angular momentum, and the theoretical implications of energy harnessing from planetary motion.
BasketDaN
If the Earth were to all of a sudden stop spinning, would it ever start up again? Basically, is the Earth only spinning because it started that way,(and it being in space, no friction to slow it down), or is there any other contributing factor?
Astronomy news on Phys.org
Basically you've got it.
To slow down the Earth has to shed both Energy and Angular momentum. The chief mechanism for that is the Tidal Effect which transfers angular momentum to the Moon and energy to the oceans. A lesser mechanism involves the fact that the Earth rotates in the Sun's magnetic field, transfering angular momentum to the sun and losing energy by eddy currents.
I wish I could understand a word anybody said on this site lol.
LOL! The way you posed the question shows that you actually do understand the concepts to which Tyger is referring, even if you don't understand the exact terminology. You asked if the Earth just "started out spinning", and there simply isn't enough friction in space to have stopped it. Tyger was basically answering "yes" to that question. The phenomenon to which you were referring (friction causing a spinning thing to slow down and stop) is a good example of what he was talking about when he referred to shedding the energy of angular momentum.
As you pointed out, in space there is not much friction; no "atmosphere" to brush against the planet's surface and absorb the angular momentum (spinning energy). However, there is the sun's magnetic field, and the moon's gravitational pull. In order to keep spinning, the Earth has to disturb both of these "forces", and so each of them exerts some brakeing power on the planet.
Another force that might be leaching away the angular momentum is a gravitational effect known as "frame dragging", which is predicted by general relativity. We do not yet have empirical evidence of frame dragging, but NASA is scheduled to launch a probe in June that should collect that evidence.
:smile: Well, welcome to Physics Forums! Rest assured that you'll get the full story here. :smile:
Hehe thanks for the help... Ya see I get all these stupid ideas,,, the one I was thinking about when I made this post was
"I wonder if the rotation of the Earth could somehow be harnessed as an energy source? I have seen pendulums that perpetually swing with no energy added to them because of the rotation of the earth... hmmm but that'd be really bad if the Earth could possibly be halted in its rotation!"
Lol yeahhhhhhhh
Lol yeahhhhhhhh
Egad, that really could get ugly! But I think you may be combining two different stories, here. AFAIK, there are no pendulums that swing perpetually because of the Earth's rotation.
However, I have seen a novelty item in the form of the pendulum that appears to continue swinging indefinitely on its own. In reality, there is a small magnet hidden in the base of the stand which continues to switch on and off giving the pendulum a "push" each time it swings. Also, there is a pendulum on display in a museum (I forget where) which is used to demonstrate the Earth's rotation. The pendulum is so large and heavy and well-made that when museum curators start it swinging in the morning, it continues to swing all day.
BTW, if we ever did find a way to harness the kinetic energy of planetary movement to perform useful work, I don't think we would ever use enough to significantly affect the motion of the planet.
You must refer to Foucault's pendulum
The source of the current rotation rate of the Earth is most likely the impact that created the moon. Also, there was a lot of angular momentum stored when the pieces that made up the Earth conglomerated.
I would expect that its mostly the later.
Well... in a frictionless environment (space), it is almost impossible for something to not be spinning, correct?
Tend to agree, RW, because Mars is an example of a planet without a significant moon (demios/phobos are small wrt planets mass) and Mars rotates at a good what 23 hrs per day. However, most of the terrestrial planets rotate more slowly, tending to orbital resonance etc. It's not impossible that Mars was struck with a massive object at some time in its past also.
  • · Replies 39 ·
  • · Replies 31 ·
  • · Replies 0 ·
  • · Replies 46 ·
12K
