Lim (n→∞)((-1)^n)/n: Does it Converge or Diverge?
  • Context: Undergrad
  • Thread starter Thread starter soul
The discussion centers on the limit of the sequence defined by lim(n→∞)((-1)^n)/n, exploring whether it converges or diverges. Participants examine both the limit of the sequence and the convergence of the associated series, addressing aspects of mathematical reasoning and convergence tests.
  • Homework-related
  • Some participants question whether the limit converges to 1 or -1, while others argue that it may diverge.
  • There is a suggestion to evaluate the limit by separating even and odd terms of the sequence.
  • Participants discuss the need to determine if the sequence is monotonic and bounded to establish convergence.
  • One participant mentions the alternating series test, noting that an alternating series converges if it decreases at least as quickly as 1/n.
  • Another participant references Leibniz's test and Dirichlet's test to support the argument for convergence of the series.
  • There is confusion about whether the original question pertains to the limit of the sequence or the convergence of the series.
Participants do not reach a consensus on whether the limit converges or diverges, and multiple competing views regarding the interpretation of the question and the methods for evaluation remain present.
Some participants express uncertainty about the original question's intent, whether it is focused on the limit of the sequence or the convergence of the series. There are also varying interpretations of the necessary conditions for convergence.
soul
I know it is easy but I need help. lim(n->infinity)((-1)^n)/n diverge or converge?and why?
p.s: question may not be understandable. Sorry for that.
what are your thoughts?? Show what you did so far!
there's a test for this type of series
Well, in fact I did not do so much. I could not decide whether it converges 1 or -1 or since we do not know where it converges if we can simply say that it is diverge.
why in the world would you think it converges to 1 or -1
I was talking about (-1)^n, when I said it converges 1 or -1.
lim(n->infinity)n
Couldn't you just evaluate the series this way?
lim(n->infinity)n
And get what?
Are you just looking whether that limit exists, or your original question requires sth else, like whether the series with the general term a_n=(-1)^n /n converges or not?
WHat is your original question.?
This is the original question. If you want to check it, you can look at p.757 of Thomas's calculus (question 24). It says that find whether this sequence is convergent or not. If convergent find the limit of it?
Well, to show that a series is convergent you first need to determine whether it is monotonic or not, then show that it is bounded. Or if the limit of that sequence exists then from a theorem we conclude that it is convergent also.
To evaluate that limit you might want to breake the problem into two parts.
First let n=2k, where k is any integer, and see where does that sequence tend to as k-->infinity.
Second take n=2k+1, or n=2k-1, where again k is any integer, and see where does that sequence tend to, as k-->infinity. If they match then the lim exists, so the sequence converges to that value.
there are other ways to show this though. Others might present you to those ways!
Or I assume you could use a test for convergence
Are you asking if this converges:
[tex]\lim_{n \to \infty} \frac{(-1)^n}{n}[/tex]
Look at the first few terms:
[tex]\frac{-1}{1}, \frac{1}{2}, \frac{-1}{3}, \frac{1}{4}, \ldots[/tex]
Do those numbers tend to get close to something?
Other people here seem to ask if you're wondering if this converges:
[tex]\sum_{n=1}^\infty \frac{(-1)^n}{n}[/tex]
Have you looked at the first few terms of that?
An alternating series will converge if it deceases at least as quickly as 1 over n. (see alternating series test)
1/n remains always positive but tends to 0 as n tends to infinity.
Using Leibnitz's test, convergence of the series you mentioned follows.
Or you could apply the Dirichlet's test.
The sequence of partial sums of (-1)^n is bounded, and 1/n remains always positive but tends to 0 as n tends to infinity.
So convergence follows naturally.
  • · Replies 17 ·
  • · Replies 19 ·
