Chemical equilibrium: Enthelpies and equilibrium contsants
The discussion revolves around calculating equilibrium constants and enthalpy changes for the reaction 2 CO2 = 2 CO + O2, with a given ∆H of 510 kJ. The user successfully calculated equilibrium constants (K) at various temperatures (1500 K, 2500 K, and 3000 K) and plotted lnK against 1/T, but encountered issues with the slope yielding an incorrect enthalpy value. The user also calculated ∆H using bond enthalpies, achieving a result of 557 kJ, which is closer to the expected value. The main challenge lies in accurately determining ∆H from the graph due to the small differences in 1/T affecting the slope calculation.
  • Understanding of chemical equilibrium concepts
  • Familiarity with the Van 't Hoff equation
  • Knowledge of bond enthalpies and their calculations
  • Proficiency in graphing and interpreting linear relationships
  • Learn about the Van 't Hoff equation and its applications in equilibrium studies
  • Explore advanced graphing techniques for better slope determination
  • Study bond enthalpy tables for accurate calculations
  • Investigate the relationship between temperature and reaction kinetics
Chemistry students, researchers in thermodynamics, and educators looking to deepen their understanding of chemical equilibrium and enthalpy calculations.
Coastal
For the system 2 CO2 = 2 CO + O2, ∆H= 510 kJ
the percentage decomposition of CO2 changes w/ temperature as follows.
Temp, K...% Decomposition
1500...0.048
2500...17.6
3000...54.8
Calculate the equilibrium constants, plot lnK vs. 1/T. In the graph, find the slope and confirm ∆H. Also, using average bond enthalpies, calculate ∆H(it should come out the same for both approaches).
1.) Slope = ∆H / R
2.) R(constant) = 8.314 J/k-mol
3.) ∆Hrxn = Sum of bond enthalpies of broken bonds - Sum of bond enthalpies of formed bonds
I started by calculating K at each temperature. We also did this part in class so I know all the K's are correct.
K at 1500=5.5 x 10-9
K at 2500=4.01 x 10-1
K at 3000=4.03 x 10
I plugged all these #s into the calculator to figure out lnK and 1/T. I plotted them on a graph and got a straight line with a negative slope. This threw me because lnK vs. 1/T should not be straight because this isn't a first order reaction. The slope was something like -40,000, which would then be multiplied by the constant R and ∆H came out to be -330,000(wrong).
Then I tried the 2nd approach. Using equation #3 above, I got ∆H= (4x799)-((2x1072)+495). I'm well aware of how to draw Lewis structures, and am positive I got all the bond enthalpies right and ∆H came out to be 557kJ, which is much closer to the 510kJ given in the problem description.
Where I am stuck is getting ∆H through the graph. Supposedly ∆H=Slope x R(constant)... but with such a small different in 1/T's or the ∆x value or the denominator in the rise/run slope formula, the slope always comes out enormous. How am I supposed to get ∆H for the first method? I looked over the numbers many times and they all seem correct.
Any help please?
I have a feeling you’re plotting your data in joules and comparing it to an answer in kilojoules. Just a hunch.
