Thread Closed
Finding Voltage in a Circuit
Share Thread
Feb21-08, 08:29 PM   #1
1. I made a quick sketch
Find V1 and V2
3. Is there an easier way to do this question without applying mesh analysis, because this question was in my chapter 2 (intro to KVL/KCL), but i cannot think of a way to find this unless i use mesh analysis. Any advice
PhysOrg.com science news on PhysOrg.com
>> City-life changes blackbird personalities, study shows
>> Origins of 'The Hoff' crab revealed (w/ Video)
>> Older males make better fathers: Mature male beetles work harder, care less about female infidelity
Feb21-08, 08:39 PM   #2
Well assuming I'm doing it right of course, you wouldn't need any simultaneous equations or anything, that'd be over complicating it, just need KCL really
so at the node above the 20 and 5 k resistors(or the equivalent 4k resistor!)you have 10 milliamps flowing in, and you need 10 mA flowing out, obtained with a voltage drop across that 4 k of just V=IR=10*4=40 Volts
You can check to see that puts 8 mA across the 5 k resistor and 2 across the 20 k, for a total of 10 mA
Feb21-08, 09:19 PM   #3
the answer for v1 = 20 V
not 40 V
so hmmmmmmmm
Feb21-08, 10:37 PM   #4
ok, so what you basically have are two resistors in series, and those two resistors(with eq. resistance of 4k) are in parallel with the other two resistors which I mentioned have an equiv. resistance of 4k as well
Since they're in parallel the current splits down both paths and equal amounts both ways since the resistances are ultimately equal, sooo it's actually V=I*R=5*4=20Volts
Feb22-08, 06:11 PM   #5
Recognitions:
Gold Membership Gold Member
If you know V1, then all you need to do is "voltage-divide" to find V2.
Thread Closed
Similar discussions for: Finding Voltage in a Circuit
Thread Forum Replies
charge and voltage across circuit Introductory Physics Homework 10
Voltage Limiter Circuit Electrical Engineering 17
What is the voltage? AC circuit Introductory Physics Homework 2
Help on low voltage indicator circuit Electrical Engineering 6
Voltage In An Electric Circuit Introductory Physics Homework 3
