Using a magnetometer to compute the magentic moment of a magnet.
The discussion revolves around the use of a magnetometer to compute the magnetic moment of a magnet, focusing on the procedure of measuring angles of deflection from compass heads and the rationale behind recording both angles for averaging.
  • Technical explanation, Conceptual clarification
  • One participant explains that the magnetometer measures the magnetic moment by recording angles of deflection on both sides of the compass heads, suggesting that these angles should be the same due to their vertical opposition.
  • Another participant questions whether the procedure involves measuring the two poles of the magnet instead of the compass.
  • A different participant proposes that averaging the two measurements helps to mitigate errors such as parallax and human error, and suggests that this practice is beneficial in engineering contexts. They also mention the value of having lab partners take separate measurements.
  • A later reply expresses agreement with the previous explanation, indicating that the reasoning provided was convincing.
The discussion contains multiple viewpoints regarding the measurement procedure, with some participants agreeing on the rationale for averaging measurements while others raise questions about the specifics of what is being measured.
Unresolved aspects include the exact nature of the measurements being taken (compass vs. magnet poles) and any assumptions related to the averaging process that may not have been explicitly stated.
manjuvenamma
Magnetometer is used to compute the magentic moment of a magnet. In this procedure, we are asked to record the angles of deflection on both sides of the compass heads (that is North and South poles of the compass), since they are vertically opposite angles, they should read the same. Why are we asked to record both and take the average of the two as the angle of deflection to apply Tangent Law?
Might it ask you to measure the two poles of the magnet (not the compass)?
It is probably just that taking the average of two separate measurements of the same quantity will average out things like parallax or human error, and will also reduce the possibility of a mistaken measurement. This is good engineering practice. If you have a lab partner, you should each make one of the measurements.
Why do websites ask you to enter your email address twice?
Good answer, Pam! I am convinced. Thanks.
  • · Replies 18 ·
13K
