Resultant Force for circular motion on a banked track
The resultant force acting on a car traveling at 77 m/s around a banked circular track with a radius of 71.9 meters and a mass of 2800 kg is determined primarily by the centripetal force. The calculations show that the normal force is 25441.9 N, and the frictional force, while calculated, is deemed unnecessary for this scenario. The correct resultant force is simply the centripetal force, calculated as 230892.91 N, which is essential for maintaining uniform circular motion.
  • Understanding of Newton's laws of motion
  • Knowledge of centripetal force calculations
  • Familiarity with forces acting on inclined planes
  • Basic trigonometry for resolving forces
  • Study the derivation of centripetal force equations in circular motion
  • Explore the effects of friction on banked curves in physics
  • Learn about the role of normal force in inclined motion
  • Investigate the impact of different angles on the stability of vehicles on banked tracks
Physics students, automotive engineers, and anyone interested in the dynamics of vehicles on banked tracks will benefit from this discussion.
dumdum000333
[SOLVED] Resultant Force for circular motion on a banked track
A car travels 77 m/s around a circular track of radius 71.9
mass of car= 2800 kg
coefficient of friction = .1
angle of track with horizontal = 22 degrees
acceleration of gravity = 9.8 m/s^2
What is the magnitue pf the resultant force on the 2800 kg driver and his car?
normal force= mgcos(angle)
force of friction = (normal force)(coefficient of friction)
i know that the force of friction and normal force do not create the centripetal force necessary to cause uniform circular motion as
Fn= 2800(9.8)cos(22)=25441.9N
Ff= 25441.9(.1)=2544.19N
and the necessary centripetal force= mv^2/r= 2800(77)^2/71.9= 230892.9068N
so i tried making the resultant= the horizontal component of Ff+horizontal component of Fn= cos(22)(2544.19)+sin(22)(25441.9)= 11889.6N which was not the right answer
What is the magnitude pf the resultant force on the 2800 kg driver and his car?
You may ignore friction. At any moment the force will be the resultant of the centripetal force and gravity. The question isn't about whether the car will stick.
never mind, the answer was just centripetal force
