Determining Equations with Squared Roots: Learn from O, P, and Q | Expert Help"
  • Thread starter Thread starter sissi169
    Roots
The discussion revolves around determining a new polynomial equation whose roots are the squares of the roots of a given cubic equation, specifically in the context of the polynomial ax^3 + bx^2 + cx + d = 0, where o, p, and q are the roots. Participants are exploring the implications of this transformation and the challenges it presents.
  • Exploratory, Conceptual clarification, Mathematical reasoning, Assumption checking
  • Participants discuss the need to express the new polynomial's coefficients in terms of the original coefficients a, b, c, and d. Some suggest using substitutions like y = x^2, while others raise concerns about the implications of negative roots on this approach. There is also mention of factoring and relating the new roots to the original ones.
The conversation is ongoing, with various methods being proposed and debated. Some participants have offered insights into the relationships between the coefficients of the original and new equations, while others are questioning the validity of certain substitutions and their effects on the roots.
There are concerns regarding the treatment of negative roots and how that affects the validity of certain substitutions. Participants are also reminded to adhere to forum rules, indicating a structured environment for discussion.
sissi169
if o,p,q are roots of the equation ax^3+bx^2+cx+d=0, determine the equation whose roots are o^2,p^2 and q^2
who can help me solve it? thank you
This is missplaced.
Please study the rules of this forum before posting.
Thread moved to Homework Help, Precalc Math.
Unless I am missing some completely obvious substitution (and I may be), this question is solvable, but not trivial to solve or explain. I'm assuming you want a new function that only has o2, p2, and q2 as roots; thus it will be cubic (barring imaginary roots). Only the constants a, b, c, and d will be different, and we want to write the new constants in terms of a, b, c, and d.
What you will need to do is to realize that [itex]ax^3+bx^2+cx+d[/itex] and [itex]x^3+(b/a)x^2+(c/a)x + (d/a)[/itex] have the same roots, because the second one is just the first one divided by [itex]a \neq 0[/itex]. The right hand side is still 0, so the solutions aren't changed.
Now, we know we can factor and get
[tex]x^3 + \frac{b}{a}x^2 + \frac{c}{a}x + \frac{d}{a} = (x-o)(x-p)(x-q)[/tex]
Multiply out and find b/a, c/a, and d/a in terms of o, p, and q. Then, suppose that the new cubic equation we want, with roots o2, p2, and q2 is
[tex]x^3 + ex^2 + fx + g = (x-o^2)(x-p^2)(x-q^2)[/tex]
Find e, f, and g in terms of o2, p2, and q2. Try to relate it to b/a, c/a, and d/a.
That last part takes some thought, but give it a try and post back if you're still stuck after trying awhile.
Usually in Further math, if we have an equation,[itex]ax^3+bx^2+cx+d=0[/itex] whose roots are [itex]\alpha, \beta, \gamma[/itex] and we want to find an equation whose roots are [itex]\alpha^2,\beta^2, \gamma^2[/itex]. A substitution such as [itex]y=x^2[/itex] gives you it directly.
Except what happens if the roots are negative? That's the problem I had with substituting y = x2. You will end up with a new equation, but the square root is always positive, so you may not come up with the same solutions. Maybe I am getting myself confused; your idea seems the more reasonable answer.
sub [itex]x=\sqrt{y}[/itex] into the equation and simplify. It doesn't matter whether or not the roots are -ve or +ve.
Suppose f(x) = (x + 1)3. The triple root is -1. If we substitute [itex]\sqrt{y}[/itex] we find [itex]f(y) = (\sqrt{y} + 1)^3[/itex] which doesn't have any real roots. Of course, this is only because we define the square root as positive, but I think that is a real concern.
[itex]f(x)=(x+1)^3[/itex] has root [itex]\alpha (=-1)[/itex] for his equation, there are 3 not one.
If a polynomial, with leading coefficient a, has roots o, p, q, then it can be written as a(x-p)(x-q)(x-o)= ax3-a(p+q+o)x2+a (op+ oq+ pq)x- aopq= 0
Similarly, the equation whose roots are p2, q2, and o2 must be of the form x3- (p2+ q2+ o2)x2- (o2p2+ o2q2+ p2q2)x- o2p2q2= 0.
You know -aopq= d so opq= d/a and o2p2q2= d2/a2. That's the constant term of the equation you are seeking. In fact if you multiply out (o+ p+ q)2 that will equal b2/a2, that should give you most of what you want.
  • · Replies 20 ·
  • · Replies 22 ·
  • · Replies 29 ·
