Can an Object Attached to a Spring Return to its Equilibrium Position Only Once?
  • Context: Graduate
  • Thread starter Thread starter OptimusPrime
    Spring Stuck
The discussion revolves around a spring-mass system subject to damping forces, specifically examining whether an object attached to a spring can return to its equilibrium position only once after being displaced and given an initial velocity. The scope includes mathematical modeling, differential equations, and the application of Newton's laws of motion.
  • Homework-related
  • An object weighing 34 lbs is attached to a spring with a spring constant of 1 lb/ft and experiences a damping force equal to twice its velocity.
  • The initial conditions of the system are specified, with the object starting 3 inches below equilibrium and moving upward at 1 ft/s.
  • One participant formulates the differential equation governing the motion of the system based on Newton's second law, leading to a linear differential equation with constant coefficients.
  • Another participant suggests trying an exponential solution involving complex numbers to solve the differential equation.
  • Further elaboration on the properties of complex exponentials and their application to the problem is provided, including the derivation of a second-degree polynomial in terms of the variable 'a'.
  • Participants discuss the implications of the solutions derived from the quadratic formula and how they relate to the system's behavior over time.
  • There is a focus on separating the solutions into real and imaginary parts to express the general solution of the system.
Participants generally agree on the formulation of the differential equation and the approach to solving it using exponential functions. However, the discussion remains unresolved regarding the specific implications of the solutions and whether the object will indeed pass through the equilibrium position only once.
Participants have not fully resolved the implications of the derived solutions, particularly concerning the behavior of the system after the object passes through the equilibrium position. There are also assumptions regarding the nature of the damping and the initial conditions that have not been explicitly stated.
OptimusPrime
An object weighing 34 lbs. is attached to a spring with spring constant 1 lb/ft. This spring-mass system is subject to a damping forece numerically equal to twice the velocity. At time t=0 the object is lowered 3 inches below its equilibrium position and given an initial velocity of 1 ft./sec in the upward direction.
Show that the object will pass through it equilibrium position exactly once and then creep back towards its equilibrium position.
Thank you
A Response by Kevin:
2004-04-21 at 13:41GMT
This is what I have so far. Please help
So the first thing we need to do is formulate the differential equation. Based on one of Newton's Laws of Motion (forgot which one offhand), the sum of the forces on a body equals the product of the mass and acceleration of the body. If we denote the displacement (in feet) of the mass from its equilibrium position by x (with positive x corresponding to the mass lying below its equilibrium position), then
spring force = -k*x, k = 1 lb/ft (Hook's Law)
damping force = -c*(dx/dt), c = 2 lb/(ft/s)
Since acceleration is the second time derivative of displacement, we arrive at
m*(d^2x/dt^2) = -k*x - c*(dx/dt)
Letting ' denote differentiation by t, we obtain the differential equation
m*x'' + c*x' + k*x = 0
with initial conditions
x(0) = x0 = 3 inches = 1/4 ft
x'(0) = v0 = -1 ft/s
Try an exponential solution, e^(i*at), and see what get.. (i sqrt(-1))
thanks
Thanks for the response,
I've been at this problem for hours. I don't know how to apply what you said into the problem. Please tell me how.
1. of all it's Newton's second law.
2. You've got what's called a linear differential equation with constant coeffecients (LDEC)
3. It has been shown, that every (LDEC) has exponential solutions, if you include the complex exponential in your definition of the exponential function.
4. Perhaps you haven't heard of the c.ex. before?
In that case:
e^(i*w)=cos(w)+i*sin(w), i=sqrt(-1)
5. If you haven't seen complex numbers before, don't be scared!
Think of a plane with the real number line as the x-axis, the y-axis is the imaginary line.
Any point in the (x,y) plane is called a complex number, and is written as x+i*y
All operations of addition and multiplication is as before, just remember that i*i=-1
TO THE PROBLEM:
6. Differentiation is just the same with a complex function, than with a real function.
7. We have, with the trial solution y=e^(i*at):
y'=i*a*e^(i*at), y''=(i*a)^(2)*e^(i*at)=-a^(2)*e^(i*at)
8. We enter these relations into the diff. eq. and get:
(-m*a^(2)+i*c*a+k)*e^(i*at)=0
9. If our trial function shall be a solution, it has to be a solution at each value of t.
Therefore, the bracketed coefficient must be 0, and we have the following equation:
-m*a^(2)+i*c*a+k=0
10. This is a second degree polynomial in a; we can now find out specifically which
values of a is allowed, given k,m,c.
11.
Using the quadratic formula, we get:
a=(-i*c+-sqrt(-c^(2)+4mk))/(-2m):
a1=i*c/m+sqrt(4mk-c^(2)))/(2m)
a2=i*c/m-sqrt(4mk-c^(2)))/(2m)
Give a message if it's something you're wondering about, or want to proceed..
Thanks so much,
Yes I want to proceed. I'm not sure how much of the problem is left to complete?
Sorry for not giving a reply sooner.
There's a bit more, but basically, we are finished.
1. If you evaluate the square root, you''ll see that it is greater than 0
2.Let's put in a1 in our trial solution:
e^(i*a1t)=e^(-c/m*t)*(cos(sq.*t)+i*sin(sq.*t)), sq.=sqrt(4mk-c^(2))/2m
If you use a2, the only difference will be a minus sign in front of the i*sin(sq.*t) term.
3. To find two real, independent, solutions, use the "real" part and the "imaginary" part.
The real part is: R(t)=e^(-c/m*t)*cos(sq.*t)
The imaginary part is: I(t)=e^(-c/m*t)*sin(sq.*t)
4. You can now write any solution as u*R(t)+v*I(t), where u and v is determined by the initial conditions.
  • · Replies 19 ·
  • · Replies 31 ·
  • · Replies 17 ·
