Understanding Rho Crit: The Critical Density of the Universe
  • Context: Graduate
  • Thread starter Thread starter marcus
    Tutorial
The discussion centers around the critical density of the universe, denoted as rho_crit, and its significance in cosmology. Participants explore its mathematical formulation, implications for the universe's flatness, and the interpretation of density in various units. The conversation includes theoretical aspects, mathematical reasoning, and conceptual clarifications.
  • One participant presents the formula for critical density as rhocrit = (3c²H₀²)/(8πG) and emphasizes its importance for understanding cosmological densities.
  • Another participant suggests an alternative expression for critical density in natural units, indicating that it simplifies to rhocrit = (3/8π) divided by the square of the Hubble time.
  • There is a discussion about the interpretation of density in familiar terms, with examples given in joules per cubic mile and cubic kilometer.
  • A participant challenges the initial formula, stating that their version is ρ=3H²/(8πG) and discusses the distinction between treating density as energy density versus mass density.
  • Another participant notes that the missing c² factor in the formula may lead to confusion and emphasizes the legitimacy of both approaches as long as one is consistent with the definitions used.
  • There is a mention of the relationship between energy density and pressure, highlighting that they share the same units, which may influence how equations are formulated.
Participants express differing views on the formulation of critical density, with some advocating for energy density interpretations while others prefer mass density. The discussion remains unresolved regarding the most appropriate approach to defining and using critical density in cosmological contexts.
There are unresolved distinctions regarding the treatment of density as energy versus mass, and the implications of these choices on the equations used. The conversation reflects a variety of perspectives on the mathematical formalism and its aesthetic considerations.
marcus
Dearly Missed
The critical density of the universe is
rhocrit = (3c2H02)/8piG
which is the average energy density required for flatness.
Many people are put off by formulas this complicated and can't say just by looking at it what the density is in familiar terms---how many BTU per cubic yard or whatever makes sense to you.
1. why does it matter what it is?
2. what's a simpler formula for it?
3. what does it actually work out to be?
1. It turns out that as far as we can tell our universe is actually flat, and so what you get from the formula (which takes into account the cosmological constant or dark energy) is our best estimate of the density of the world. Cosmologists are in the habit of giving other densities (like matter, radiation, dark matter, etc) as FRACTIONS of rho crit. So if you know rho crit you can interpret what they are saying and if you don't you cant. So it is good to know.
2. In natural units (c=G=hbar=1) the critical density is simply
rhocrit = (3/8pi) divided by the square of the Hubble time.
The Hubble time is 1/H0. It works out to around 8E60 in natural units or about 13.8 billion years. When you see E60 in natural units that is the same order of magnitude as a billion years---same ballpark timescale. The square of the Hubble time is about 64E120.
The number (3/8pi) is roughly 1/8 so rho crit works out to
around 1/8 divided by 64E120. It is a very small density which is good because if it were bigger the universe would go crunch.
If you need more precision in line with presentday accurate measurements of the Hubble parameter, use 8.06E60 for the time.
rhocrit = (3/8pi) tH-2
Note that the Hubble time is not generally equal to the age of the universe although in some models it may be fairly close to it. The Hubble parameter is something that is directly measureable from data on observations----whereas the age is something people theorize about and infer from models. Different beasts.
3. To take a for instance: a density which is 2 joules per cubic mile works out to be E-123 in natural units.
So if some density happens to be 1.8E-123 in Planck, and you want to interpret it in everyday language, you can call it 3.6 joules per cubic mile. This will be considered perverse by metric purists who abhor miles----therefore, so that the purists may rejoice, we say that E-123 is half a joule per cubic kilometer. Then 1.8E-123 comes out to be around 0.9 joule per cubic km. None of this appears to matter much because it is just translation into some arbitrary conventional terms. I find it's more useful to know in Planck.
4. In case you like differential equations the two Friedmann equations are what the Einstein GR equation boils down to assuming a nice homogeneous isotropic universe and the second
Friedmann says (in the zero curvature case):
H02 = (8piG/3c2) rho
that tells what rho has to be in the zero curvature case and
it's easy to rearrange that equation so as to solve for rho,
and it gives the definition of rho crit quoted at the beginning.
This may be why rho crit is so useful----its definition is a disguised
form of one of the two favorite equations of cosmology.
Astronomy news on Phys.org
I think you ought to check that, the ρcrit I have is
ρ=3H2/8πG
you can get at it through the Friedmann equations or by equating KE and PE for moving objects and gravity, respectively.
ρ=3H2/8πG
if you look back, i nearly always say that I am looking at rho as an energy density
if you treat it as a mass density, the formula is what you say
(the formula is missing a c^2 factor because you divide out c^2 to turn energy terms into the "equivalent" mass m = E/c^2)
it is one possible way to do the accounting
but if you treat the energy densities as actual energy densities then the formula is as I say.
The version of the Friedmann eqn that you are using probably has rho as a mass density and therefore is missing a c^2 term
so when you solve for rho you naturally get a mass density.
it is legit to go either way as long as you remain alert to which
form of accounting you are using
personally, many of the densities in space that interest me are more natural to think of as energy densities
and the orig. GR eqn were of course written using energy-momentum tensor (getting away from mass idea)
IMPORTANT SIDE NOTION energy density has the same units as pressure
if your First Friedman eqn has (rho + 3p) term then it is adding energy density directly to pressure ------mass density will not add like that
mathematically cleaner to us energy (not mass) density,
however math formalism is ultimately a matter of esthetics and
de gustibus non disputandum est
ok fine.
  • · Replies 16 ·
  • · Replies 24 ·
  • · Replies 0 ·
