Relationship between Linear Algebra and Differential equations
The discussion centers on the relationship between linear algebra and homogeneous linear differential equations, particularly focusing on the general solution of such equations and the role of linear differential operators. The scope includes conceptual understanding and application of these mathematical concepts.
  • Homework-related
  • One participant describes the relationship between homogeneous linear differential equations and linear algebra, stating that the general solution is a linear combination of n linearly independent elements of ker(L), where L is a linear differential operator.
  • Another participant expresses satisfaction after reviewing examples in class, indicating that solving higher-order homogeneous linear ordinary differential equations (O.D.E.s) is straightforward, especially compared to previous challenges in linear algebra.
  • A different participant comments on the ease of solving homogeneous linear O.D.E.s with constant coefficients, while also noting the potential complexity of dealing with equations that have variable coefficients.
  • One participant acknowledges the difficulty of mastering the linear algebra concepts that underpin the solutions to these differential equations, suggesting that the material may become more challenging over time.
Participants express varying degrees of confidence in their understanding of the relationship between linear algebra and differential equations. While some find the concepts straightforward after examples are provided, others highlight the challenges that may arise, particularly with more complex equations.
There is an implicit assumption that the understanding of linear algebra is foundational for grasping the solutions to homogeneous linear differential equations. The discussion does not resolve the potential difficulties associated with variable coefficients in O.D.E.s.
This discussion may be useful for students studying linear algebra and differential equations, particularly those seeking to understand the connections between these areas of mathematics.
discoverer02
I just came from a class lecture that tied together the relationship between linear algebra and differential equations. The lecture dealt only with homogeneous linear equations. I understood about 90% of it and want to try to tie together the loose ends.
In a nutshell, if I have a homogeneous linear differential equation of degree n, where L is a linear differential operator of order n. Then the general solution of the homogeneous linear differential equation is the linear combination of n linearly independent elements of ker(L).
I haven't seen this applied to an example yet, so it's not entirely clear, but have I stated the relationship correctly?
I guess I'll see examples tomorrow, but I'd like to go into class with a crystal clear picture, so I can following along with what will probably be another lightning quick lecture.
Can anyone provide a simple example?
Thanks.
Nevermind.
We went over everything once more and finally went over some examples. Solving higher order homogeneous linear O.D.E.'s couldn't be easier. It's like a breath of fresh air after a month of sometimes grueling linear algebra.
:biggrin:
Solving homogeneous linear O.D.E. with constant coefficients is as easy as solving a polynomial equation. I, personally, could imagine easier things than solving a fifth order homogeneous linear O.D.E with constant coefficients. You will probably soon have to deal with equations with variable coefficients!
You're absolutely right. I guess I was caught up in the moment. I really had to work hard to stay on top of the linear algebra that leads up to this revelation.
In the long run, I'm sure it only gets tougher.
  • · Replies 19 ·
