Understanding Z-Pinch Plasma Behavior for Hydrogen Ion Stream Compression
  • Context: Graduate
  • Thread starter Thread starter lilrex
    Behavior Plasma
The discussion focuses on the application of the Z-pinch effect for compressing hydrogen ion streams. It emphasizes the potential for discharging a current through the ion stream to create a magnetic field that influences the stream. The participant expresses uncertainty about the conductivity of a hydrogen ion beam at 20KeV and its behavior as plasma, particularly regarding the physical spacing and charge of the ions. Experimentation is suggested as a means to explore these concepts further.
  • Understanding of Z-pinch plasma physics
  • Knowledge of ion beam dynamics
  • Familiarity with plasma conductivity principles
  • Basic concepts of electromagnetic fields
  • Research the principles of Z-pinch plasma confinement
  • Study the behavior of hydrogen ion beams at high voltages (20KeV)
  • Explore experimental setups for testing plasma conductivity
  • Investigate the effects of electromagnetic fields on ion streams
Researchers in plasma physics, experimental physicists, and engineers working on ion beam applications or magnetic confinement systems.
lilrex
I am still trying to get a handle on plasma behavior, if I had a gap intended to apply a field for the purpose of compressing a hydrogen ion stream, using the Z-pinch effect could one discharge a current through the ion stream to affect the Z-pinch? I am thinking that it would, that the electrons will flow through the ion stream and create the magnetic field that would influence the Ion stream.
I appreciate help on this, I am just kind of thinking out loud and this is a good place to have questions like this answered.
more specifically speaking I know that plasma is highly conductive, I am just not sure how conductive a hydrogen ion beam is, at say 20Kev, it stands to reason that it would behave like any other plasma, but I don’t know much about it in this circumstance, like I am thinking (just hashing it out in my head) that the physical space between the ions, and the charge of the ions could prevent it from being neutral enough to become conductive (i am not sure if I am using the terminology right here).
maybe I should just try it and find out. good ole experimentations!
  • · Replies 0 ·
