| Thread Closed |
mechanical electricity generation |
Share Thread |
| Feb28-08, 09:06 PM | #1 |
I was just thinking last night about the generation of electricity.
Are there any mechanical forms (as opposed to chemical or solar or other) of electricity generation that are not ultimately dependent on permanent magnets? If we had no permanent magnets, would we have any way to generate electricity from mechanical processes such as wind, hydro, steam(coal, thermal, nuclear) etc.? |
| Feb28-08, 10:15 PM | #2 |
CS |
| Feb29-08, 12:17 AM | #3 |
These seem to qualify
Van de Graff generators. Piezo generators |
| Feb29-08, 01:19 AM | #4 |
Recognitions:
Look at this stepwise:
First there are mechanical (non-magnetic) means of generating static electricity See http://en.wikipedia.org/wiki/Electrostatic_generator. Once you have found a way of generating static electricity, you can store the charges with a Leyden jar, which is essentially a capacitor. So once you've got a primitive capacitor you could connect it to a circuit as a voltage source, which you can then use to make an electromagnet. And from there you can use the electromagnet to generate current. Of course once you've got a charged Leyden jar you could already use it as a current source. |
| Nov3-11, 07:10 PM | #5 |
It is possible to use a large mechanical storage system, by using a small amount of electicity and store it in large knetic storage unit and then itcan be used to produce largrer amounts of electricity. This is totally Green electricity and does not require nuclear dirt, polluting fuel burning, sun that does not always shine, wind that is not constant, nor water that can freeze or run dry, hoping containment does not breach. This would work much like a wind turbine but work 100% of the time and yet has been over looked by all power companies though it has worked in the long past and with todays new materials technology would allow this to work today!!!!!!!!!!!!!!!!!! K.I.S.S.
| Nov3-11, 07:19 PM | #6 |
Mentor
Sorry, no it isn't. Conservation of energy is the law.
This is a necropost and not useful, so thread locked. |
| Thread Closed |
Similar discussions for: mechanical electricity generation
| Electricity generation through crystals | General Physics | 10 | ||
| A mechanical engineering student hating mechanical design | Academic Guidance | 14 | ||
| The Physics Involved in Coal-Fired Generation of Electricity | Introductory Physics Homework | 1 | ||
| Is every mechanical process or mechanical reversible? | Mechanical Engineering | 4 | ||
