Where Can I Find Experimental Data for Aero Engine Performance Validation?
  • Thread starter Thread starter wenhai
    Engine Test
The discussion revolves around the challenges of finding experimental data for validating aero engine performance, particularly in the context of a Ph.D. research project. Participants explore the availability of test data, methods for simulating aero engines, and the complexities involved in modeling engine components.
  • One participant has calculated compressor and turbine performance using a 1-D control volume method and seeks experimental data for the entire aero engine.
  • Another participant notes the scarcity of test results due to the high costs associated with data collection by companies like GE and Rolls-Royce.
  • A participant mentions that while modern engine test results are confidential, older data from NASA may be available, but they have not found comprehensive engine data.
  • Concerns are raised about the feasibility and accuracy of simulating an entire engine using a 1-D method, especially given the complexity of interactions between components.
  • One participant suggests that existing literature, such as Hill and Peterson's work, discusses components individually rather than as a complete engine.
  • Another participant proposes two approaches for simulation: calculating components sequentially or analyzing the influence of each component on the others, expressing a preference for the latter due to concerns about stability and physical reasoning.
  • Discussion includes the sensitivity of multi-stage compressor calculations and the cascading effects of changes in one stage on others.
  • A participant reiterates the difficulty in obtaining experimental data necessary for validation of their calculations.
Participants express a consensus on the difficulty of finding experimental data and the complexities involved in simulating aero engines. However, there is no agreement on the best approach to simulation or the feasibility of using a 1-D method for the entire engine.
Participants acknowledge limitations in available data and the challenges posed by the complexity of engine component interactions. The discussion reflects a range of assumptions about the methods and data availability without resolving these uncertainties.
wenhai
I have calculated the compressor and turbine with the 1-D control volume method, what I need to do next is to simulate the whole aero engine. unfortunately, I could not find any aero engine case that contains the geometry and test performance, I am studying for my PH.D and am anxious about it, could anyone give me some hints that how could I find or buy such of the case?
thanks in advance
There is a reason why test results are sparse...
Companies (GE, RR, etc) spend a lot of money collecting them either in their own labs or by others. Now what is it exactly that you would like to know?
thank you
I know the test results for the modern engine are confidential, however, some of the old engine test data may be possible. as we know, NASA has released some old compressors and turbines test cases, which could be found on the internet, but I did not find the case for the whole engine.
what I want to know is the geometry and performance of the engine, like the coordinate along the mean line, and the metal angle for compressor and turbine, the performance of the engine, so that I could compare the calculation results with the test data. which is part of my PH.D research.
the method we use is the 1-D control volume method solving the unsteady Euler equation with the source terms. the simulations with the compressor and turbine have been done by previous ph.d student, and I begun my PH.D last October, my professor wants me do the research in the field, but nowadays the 3-D solving N-S equations seem be the hot topics, and I also wonder whether it is possible to simulate the whole engine with 1-D method, what about the accuracy?
could anyone give me some suggestions?
thanks a lot
I can't say I have seen anything that goes from stem to stern in one treatment like you are looking for. If you look at something like Hill and Peterson's Mechanics and Thermodynamics of Propulsion, they discuss each type of component individually. It would be up to you to do it as a complete engine.
http://www.grc.nasa.gov/WWW/K-12/airplane/ngnsim.html
thanks, FredGarvin, it is interesting program. you gave a good suggestion
in fact, I had discussed with my professor how we could simulate the complete engine, it seemed 2 possible way, one way is to calculate the component one by one, the other way is to calculate each component individually and research the influence between each component. I prefer the second one, because I am not sure that the first one is whether physical reasonable and calculational stable.
and is it meaning to simulate the complete engine with only 1-D method? I read many papers that only focus on one of the component of engine, just like the compressor, combustor or turbine...
I think the reason that is so is because of the incredible complexity inherent by putting all of the components together like that. For example, think of modeling a 3 or 5 stage compressor. A small change in say relative wind for the first stage can have cascading effects on the last stages. I can't say what it is like to try to add all of the items together. Then again, I have never had to go through matching engine components. That may be a good place to look into.
yes, the calculation for the multi-stages compressor will be sensitive and more unstable. the interaction between different component is a very interesting field, however, I need the test data to validate my calculation, It seems it is really hard to find available test data. How could I get the experimental data?
thanks
