Series and convergence/divergence
  • Thread starter Thread starter Niles
    Series
The discussion revolves around determining the convergence or divergence of a specific series involving alternating terms and logarithmic factors.
  • Exploratory, Assumption checking, Mathematical reasoning
  • Participants explore various tests for convergence, including the integral test, ratio test, root test, and Leibniz test. Questions arise regarding the applicability of these tests and the conditions required for the Leibniz test.
Participants are actively discussing potential methods to analyze the series, with some suggesting specific tests while others seek clarification on the conditions for these tests. There is no explicit consensus on the best approach yet.
Some participants express uncertainty about the complexity of certain tests and the conditions that must be met for convergence criteria, particularly regarding the behavior of the sequence as n approaches infinity.
Niles
Determine whether the series converges:
[tex] \sum\limits_{n = 2}^{\inf } {\frac{{( - 1)^n (n^2 + 1)^{1/2} }}{{n\ln (n)}}} [/tex]
Which test must I use? I thought of using the integral test, but it seems a little too hard. Are there other possibilities?
Try either the ratio or root test. Neither would be very easy to calculate, but...
Well, the [itex](-1)^n[/itex] should give you an easy test...
BTW: \infty is [itex]\infty[/itex]
Should I just take:
[tex] \sum\limits_{n = 2}^{\inf } {\frac{{( - 1)^n (n^2 + 1)^{1/2} }}{{n\ln (n)}}}^{(1/n)} [/tex] and take the limit of this?
Its an alternating series, what about the Leibinitz test?
I looked at the Leinitz test - on wikipedia they write about the first condition:
"If the sequence a_n converges to 0, and .." - does this mean the limit of a_n for n -> infinity?
