Calculating Weight of Roll Cage Tubing: Density & Cost
The discussion revolves around calculating the weight of roll cage tubing, both solid and hollow, using material density. Participants explore methods for estimating the weight to determine costs associated with constructing a roll cage, including considerations for labor and additional materials.
  • Homework-related
  • One participant inquires about calculating the weight of roll cage tubing using material density and seeks advice on estimating costs.
  • Another participant suggests that multiplying volume by density provides the overall mass, emphasizing the need to account for labor and other materials.
  • A formula for calculating the volume of a hollow tube is provided, with specific variables defined for outside diameter, inside diameter, and length.
  • For solid tubing, it is noted that the inside diameter is zero, and the same volume calculation applies.
  • Participants discuss whether a bent tube should be treated as a segment or an equivalent length segment in calculations.
  • There are inquiries about resources for estimating steel material costs, with suggestions to search for local steel tube merchants and their pricing tables.
  • Another participant asks about calculating the volume of square and hexagonal tubes, with formulas provided for both shapes, indicating that the same principles apply.
  • Clarifications on the volume calculations for square and hexagonal tubes are shared, with specific formulas and variables outlined.
Participants generally agree on the methods for calculating weight and volume, but there are varying opinions on the treatment of bent tubes and the complexity of calculating volumes for different shapes. The discussion remains unresolved regarding the best approach for estimating costs and the specifics of material pricing.
Limitations include potential missing assumptions in the calculations, dependence on specific definitions of tube dimensions, and unresolved details regarding the cost estimation process.
This discussion may be useful for individuals involved in engineering, automotive design, or construction projects requiring knowledge of material costs and weight calculations for tubing.
OutCell
Hi,
How do i calculate the weight of a roll cage tubing, solid or hollow, by knowing the material density?
I am trying to estimate the cost of the cage by calculating the weight. Is that possible? Or should i look at estimating the roll cage from a different point?
Would really appreciate any ideas
Thanks
Well, volume*density will give you the overall mass. So if you know the volume of all of the tubing used and you know the price per pound of the material, then all you have to do is account for time for labor and other materials required for construction.
OutCell said:
Hi,
Thanks
For a hollow tube:
[tex]V = (d_o^2 - d_i^2) \frac{\pi}{4} \cdot L[/tex]
where,
do = outside diameter (ft)
di = inside diameter (ft)
L = length (ft)
Then multiply by the density in pounds per cubic foot to find the weight in pounds. Multiply by the cost per pound for the total cost of the tube.
If it is solid, then di is zero. Everything else is the same. Of course you'll need to sum all of the tube segments.
Plus like Fred mentioned, there is a labor cost and a cost for any other componets to the cage.
Hope this helps.
CS
Thanks for your time and answer i really appreciate it. This is exactly what i was trying to confirm :)
stewartcs said:
For a hollow tube:
where,
L = length (ft)
Hope this helps.
CS
Excellent. Thanks a million, this is what i was looking for exactly. Does a bent tube act as something other than a segment or should i just consider it as a segment and add it up?
Any good sites where i can find a good estimate of steel materials cost? In English pounds if any :)
OutCell said:
...Does a bent tube act as something other than a segment or should i just consider it as a segment and add it up?
Just add it in as an equivalent length segment.
CS
CS
Thanks CS
Google search the name of your local steel tube merchant. They more than likeley have tables on the net that give kG per meter or pound/foot for all the different sizes and grades. We have several catalouges in the office here with all that infomation and more.
The merchant may also have posted their RETAIL rates for purchase although these are far higher than if you send them a nice material schedule and ask for a quote. If you make sure your schedule lists how many of each size and grade you require and also purchase in standard lengths so the mechant doesn't have to do your leg work then they are also more likly to offer a better price. My general rule "The more you nag the more it costs" and this applies to anything.
Thanks. I will send them an email and explain why i need the costs. I am actually not buying the material, i only need the cost so i can calculate an estimate for my report/project in university.
Appreciate your help and time, thanks :)
How would you calculate the volume of a square and hexagonal tube (hollow/solid)?? Would it be a complicated method?
The same concept is used.
For example the area of a square is just Length times Width (since it is square it is L times L). Hence...
[tex]V = (d_o^2 - d_i^2) \cdot L[/tex]
For a hexagon the volume is,
[tex]V = \frac{3 \sqrt{3}}{2} \cdot (t_o^2 - t_i^2) \cdot L[/tex]
where,
to = the edge length of the outer hexagon
ti = the edge length of the inner hexagon
CS
where,
CS
Waw, i guessed the square right but your way of the hexagon is easier than what i found :) i greatly appreciate your help
V= 〖[((3 √3)/2 x l^2)〗_out- 〖((3 √3)/2 x l^2)〗_in] x L , this was my hexagon way :P
  • · Replies 22 ·
20K
  • · Replies 29 ·
  • · Replies 29 ·
10K
