Calculating the Sun's Bending Angle on a Ray of Light
The bending angle of a ray of light passing near the Sun, specifically one million miles from its center, can be calculated using the formula 4M/R radians, where M represents the Sun's mass and R is the distance of closest approach. The Sun's mass can be derived from the Earth's orbital speed and distance, leading to a straightforward calculation of the bending angle as 4M divided by E44. In metric units, the formula adjusts to 4GM/c²R, yielding the same result in radians. The expected deflection is approximately 2 parts in a million, or a few microradians.
  • Understanding of gravitational physics and general relativity
  • Familiarity with natural units (c=G=hbar=1)
  • Basic knowledge of orbital mechanics and Kepler's laws
  • Proficiency in metric unit conversions and calculations
  • Research the implications of gravitational lensing in astrophysics
  • Study the Schwarzschild radius and its significance in black hole physics
  • Explore advanced topics in general relativity, focusing on light propagation in gravitational fields
  • Learn about the historical experiments that confirmed the bending of light by gravity
Astronomers, physicists, students of general relativity, and anyone interested in the effects of gravity on light propagation.
A ray of light passing a million miles from the sun is bent...
  • 0 radians
    Votes: 0 0.0%
  • 3.7 nanoradians
    Votes: 0 0.0%
  • 3.7 microradians
    Votes: 5 100.0%
  • 3.7 milliradians
    Votes: 0 0.0%
  • Total voters
marcus
Dearly Missed
By how much, if at all, is a ray of light bent when it passes by the sun a million miles from center?
The bottom line is, do you have an order-of-magnitude feel for the sun's gravity? Can you judge the rough size of the bending angle well enough to spot it in the line-up?
In natural units (c=G=hbar=1) the answer is simply 4M/R radians, where M is sun's mass and R the distance of closest approach----a million miles being E44.
The sun's mass? Well the Earth's orbit speed is E-4 and its distance from the sun is 93E44 (93 million miles). So the sun's mass is 93E44 multiplied by the square of E-4.
The mass of a central body equals the radius of any circular orbit multiplied by the square of the orbit speed. This assumes the orbiter is small compared with the central body, and the Earth is that.
M, as you can see, is easy to find and the angle is simply 4M divided by E44.
The corresponding thing is messy in metric----distance 15E10 meters, orbit speed 3E4 meters per second, then divide by
G = 6.673E-11 cubicmeters/squaresecond per kilogram,
which gives the mass M in kilograms. Then the angle is 4GM/c2R, where R is the distance of closest approach.
What natural units do for you in this case is get rid of the Gees and the cees, making things a little less bother. The answer comes out in radians either way---doesn't matter whether you work in natural units or in metric.
Astronomy news on Phys.org
The Sun as a black hole would have a Schwarzschild radius of 3 km. 1.5 million km is 500,000 times that, so you expect a deflection of the order of 2 parts in a million, or a few microrad.
  • · Replies 18 ·
  • · Replies 46 ·
9K
