Serious problem about Differential equation
This discussion addresses three key problems related to solving ordinary differential equations (ODEs) using power series. The first problem involves solving the equation xy' - 3y = 3, where participants clarify the process of equating coefficients of power series. The second problem defines an ordinary point as a location where a differential equation is analytic, emphasizing the importance of Taylor series. Lastly, the discussion questions the necessity of determining the radius of convergence when solving ODEs, concluding that while not essential, it can simplify the process.
  • Understanding of ordinary differential equations (ODEs)
  • Familiarity with power series and Taylor series
  • Knowledge of analytic functions and their properties
  • Basic skills in manipulating series and coefficients
  • Learn how to solve ODEs using power series methods
  • Study the properties of analytic functions and Taylor series
  • Research the concept of radius of convergence in power series
  • Explore Legendre polynomials and their derivation techniques
Students and professionals in mathematics, particularly those focusing on differential equations, applied mathematics, and mathematical analysis.
kthouz
Hi! I have 3 really problem here that i beg anyone who knows more to help me:
1. How to solve the equation of the kind xy'-3y=3 using power series.
I usually solve kind pf homogeneous equations. Here the problem rises when i want to equalise all the coefficient of x^n to 0. Because of that 3 there i don't now how to procede.
2. I don't know what is exactly an ordinary point. They say that an ordianry point is a point at which an ordinary differential equation is "analytic",but i don't understand that term "analytic".
3. Is it important to look for the radius of convergence first, when you want to solve an ODE using power series? I always consider around x=0.
That is exactly why memorizing formulas without recognizing them is a mistake!
If this were xy'- 3y= 0,you would know what to do? Then you would write [itex]y(x)= \sum_{n=0}^\infty a_n x^n[/itex] so that [itex]y'(x)= \sum_{n=1}^\infty n a_n x^{n-1}[/itex] and your equation would be
[itex]xy'- 3y= \sum_{n=1}^\infty n a_n x^n- \sum_{n=0}^\infty 3a_n x^n= 0[/itex]
Notice that the first sum is from 1 to infinity while the second sum is from 0 to infinity. That happens because when you differentiate a power series, you lose the first term. Of course, since you say you can solve homogenous equations, you know that you need to treat that case separately: If n= 0, 3a0= 0 so a0= 0. If n> 0 then
nan- 3an= (n- 3)an= 0 which makes the solution kind of trivial! Either an= 0 or n= ? (Of course, it's a separable equation and easy to solve that way.)
The only difference now is that you have
[itex]xy'- 3y= \sum_{n=1}^\infty n a_n x^n- \sum_{n=0}^\infty 3a_n x^n= 3[/itex]
You can think of that right hand side as 3x0 in order to match it to the left hand side. Again, do the n=0 case separately: 3a0= 3 so a0= 1 now. Do you see what to do if you had x2 or 3+ x2 on the right side? For some more complicated function, like ex or cos(x), expand them in their Taylor series and then equate corresponding coefficients.
A real valued function is analytic at a point if its Taylor's series exists at that point (so it must be infinitely differentiable in order to have a Taylor's series) and converges to the function on some neighborhood of the point. Caution- there exist functions that "have" Taylor's series but the radius of convergence is 0. There exist functions that have Taylor's series that converge for all x but not to the function! Fortunately for you almost all, if not all, of the examples you will see are "not analytic" because they have a factor in the denominator that goes to 0 at that point.
I wouldn't consider it "necessary", although it might save you some work if you found the radius of convergence was 0!
You shouldn't consider only "around x= 0". You might well have a problem where the "initial condition" is given at some point other than x= 0. If you were told that y(a)= 1, satisfying that condition will be much easier if you wrote [itex]y= \Sum a_n (x- a)^n[/itex]. Or you could "shift" your variable: write t= x- a and rewrite the equation in terms of t rather than a.
Thanks!
And can someone show me (give me hint on) how to find legendre polynomials on 1st and 2nd degrees using (1-2xh+h^2)^(-1/2)=∑h^n P_n(x) .
  • · Replies 52 ·
10K
  • · Replies 24 ·
