Change in kinetic energy in a 2-car collision
The problem involves a two-car collision where one car is heavier and traveling at a different speed compared to the lighter car. Participants are tasked with calculating the change in kinetic energy of the system during the collision, with specific values provided for the masses and speeds of the cars before and after the collision.
  • Participants discuss calculating the total kinetic energy before and after the collision, with some attempting various combinations of formulas. Questions arise regarding the conservation of kinetic energy and momentum in the context of the collision type.
Some participants have provided calculations for kinetic energy before and after the collision, while others express confusion about the conservation principles involved. There is acknowledgment of the calculations presented, but also a clear distinction made regarding the nature of the collision, with emphasis on momentum conservation rather than kinetic energy conservation.
Participants are navigating the complexities of elastic versus inelastic collisions, with some misunderstanding the implications of energy conservation in this scenario. There is an ongoing exploration of assumptions regarding the collision type and its effects on kinetic energy calculations.
clope023
[SOLVED] change in kinetic energy in a 2-car collision
When cars are equipped with flexible bumpers, they will bounce off each other during low-speed collisions, thus causing less damage. In one such accident, a 1850kg car traveling to the right at 1.60m/s collides with a 1450kg car going to the left at 1.10m/s . Measurements show that the heavier car's speed just after the collision was 0.270m/s in its original direction. You can ignore any road friction during the collision.
a) What was the speed of the lighter car just after the collision?
got this to be .597m/s
b) (where I'm stuck) Calculate the change in the combined kinetic energy of the two-car system during this collision.
[tex]\Delta[/tex]K = K2-K1?
I'm pretty sure I'm missing something obvious, but I'v tried like 5 different combinations.
(1/2(ma + mb)(v2a+v2b)^2)-(1/2(ma+mb)(v1a+v1b)^2) = 190J wrong
with other combos I've gotten as high as 1490J which was also wrong.
any help is greatly appreciated.
You know the speed of each car before and after the collision. So just calculate the total kinetic energy before and after and compare. Calculate the KE of each car separately, then add them up.
okay, so:
K1a = 1/2(1850)(1.60)^2 = 2368J
K1b = 1/2(1450)(1.10)^2 = 877J
K2a = 1/2(1850)(.270)^2 = 67J
K2b = 1/2(1450)(.597)^2 = 258J
deltaK = (2368+877)-(67+258) = 2920J?
Looks good to me. (Assuming you calculated the final speed of the lighter car correctly; I didn't check.)
Edit: I just confirmed your speed calculation.
thanks, yeah I know part A is right for sure (masteringphysics)
thanks again Doc Al!
As i understood it, the two cars collided with an elastic form of collision. Therefore momentum and kinetic energy is conserved (same before and after the collision). How come that in the computation of the two kinetic energy before and after (the one you presented with us) are not equal (3245 J before collision and 325 J after collision)? I thought they will be equal. This is confusing for me.
You just showed combined kinetic energy.
Please help me. Explain it in detail.
No, the collision is not elastic. Only momentum is conserved. You have enough information to solve for the final speeds using only conservation of momentum (that was part a).
(Realize that you are responding to a post that is over three years old.)
  • · Replies 22 ·
