Friction stopping a car
by scooby07
Tags: friction, stopping
scooby07
scooby07 is offline
#1
Mar2-08, 04:38 PM
P: 2
Given two cars, one heavier than the other but identical in all other respects, traveling at the same speed on a snowy or icy road which one will stop sooner?
Momentum would say that the lighter car should stop sooner but how does the heavier car's increased weight in combination with friction figure into the stopping distance? Shouldn't the heavier car be able to dig into snow more increasing the opposing frictional force? On ice even though neither car can "dig in", wouldn't the heavier car experience a greater frictional force causing it to stop sooner or is the increased momentum greater than this increase friction?
Explanations are fine as are equations. Thanks for the help.
Phys.Org News Partner Science news on Phys.org
Internet co-creator Cerf debunks 'myth' that US runs it
Astronomical forensics uncover planetary disks in Hubble archive
Solar-powered two-seat Sunseeker airplane has progress report
basePARTICLE
basePARTICLE is offline
#2
Mar2-08, 04:53 PM
P: 86
One dependency is how much the angular momentum at the wheels is shifted into linear velocity. . .
p.s. this is a true driver dependency.
scooby07
scooby07 is offline
#3
Mar2-08, 04:59 PM
P: 2
How about I simplify the problem.
Let's just say neither car has ABS and to stop both drivers choose to mash on the brakes and lock up the wheels.
So essentially both cars are just sliding blocks.
basePARTICLE
#4
Mar2-08, 05:22 PM
P: 86
Frictional force is independent of weight, but dependent on material composition.
Momemtum is mass * velocity. p = mv. Friction will retard speed.
Friction uses energy directly. Kinetic energy(KE) is (m * v * v)/2.
So let us say KE = mK for this example. Friction will leave r*m*k units of energy to continue the work.
With one mass m1 and the other m2, the KE ratio, yields m1/m2 as the deciding factor of who travels the furthest. Example, if both cars are identical, then m1 = m2, and they both stop at the same time. This makes sense because you know heavier cars use more gas to attain the same speeds as lighter cars and since friction is independent of weight, the solution is complete.
The important point is at the beginning of this post.
kamerling
kamerling is offline
#5
Mar2-08, 09:35 PM
P: 457
Quote Quote by basePARTICLE View Post
This doesn't make sense. Sliding friction depends linearly on weight. F = k.mg
where k is the coefficient of friction. If you combine that with F=m.a to compute the deceleration of the car, you'll see that THAT doesn't depend on mass.
Register to reply
Related Discussions
Stopping distance considering coefficient of friction Introductory Physics Homework 6
Stopping a car. Advanced Physics Homework 7
Friction and stopping General Physics 5
Friction and stopping distance Introductory Physics Homework 5
stopping the car Introductory Physics Homework 2
