[SOLVED] Constructive and destructive interefernec and a pair of speakers
by TFM
Tags: constructive, destructive, interefernec, pair, solved, speakers
TFM
TFM is offline
#1
Mar3-08, 10:30 AM
P: 1,031
Two loudspeakers, A and B, are driven by the same amplifier and emit sinusoidal waves in phase. Speaker B is 2.00 m to the right of speaker A. Consider point Q along the extension of the line connecting the speakers, 1.00 m to the right of speaker B. Both speakers emit sound waves that travel directly from the speaker to point Q
What is the lowest frequency for which constructive interference occurs at point ?
What is the lowest frequency for which destructive interference occurs at point ?
2. Relevant equations
not sure
3. The attempt at a solution
I know that constructive occurs when waves are in phase, destructive when 180 degrees/pi radians out of phase
Any ideas would be most appreciated
Thanks,
TFM
Phys.Org News Partner Science news on Phys.org
Better thermal-imaging lens from waste sulfur
Hackathon team's GoogolPlex gives Siri extra powers
Bright points in Sun's atmosphere mark patterns deep in its interior
kamerling
kamerling is offline
#2
Mar3-08, 04:31 PM
P: 457
If speaker_a produces a signal sin(2*pi*f * t), what will be the signal at a point a distance d_a from a? This is just the same signal delayed by the time to get to the
distance d_a
This will still be a sine wave so the signal looks like sin(2*pi*f*t - .........)
speaker_b produces the same signal, so the same applies at a distance b_d from b.
The total signal is just the signal from both speakers added.
d_a and d_b are given in the problem
TFM
TFM is offline
#3
Mar4-08, 05:40 AM
P: 1,031
I am not sure what you mean by signal?
TFM
TFM
TFM is offline
#4
Mar5-08, 01:37 PM
P: 1,031
Constructive Interference occurs at [tex] n\lambda [/tex]
Destructive Interference occurs at [tex] \frac{n}{2 \lambda}[/tex]
Using the basic wave equation, speed = wavelength * frequency, they can be rearranged for frequency:
Constructive Interference occurs at [tex] n(\frac{344}{f}) [/tex]
Destructive Interference occurs at [tex] n(\frac{344}{2f}) [/tex]
but I am unsure how I should proceed from now?
(I hope this is relevant)
Any help would be much appreciated,
TFM
TFM
TFM is offline
#5
Mar5-08, 04:00 PM
P: 1,031
Looked in my book, fpuind the right equation:
constructive:
[tex] f_n = \frac{nv}{d} [/tex]
destructive:
[tex] f_n = \frac{nv}{2d} [/tex]
where d is the path difference.
TFM
Register to reply
Related Discussions
Constructive Interference Problem with 2 Speakers Introductory Physics Homework 1
Confused on Constructive/Destructive Interference!!! Introductory Physics Homework 2
Constructive/Destructive Interference Introductory Physics Homework 1
Constructive/Destructive Interference Problem. Introductory Physics Homework 10
speakers in a field/ destructive interferece Introductory Physics Homework 1
