Constructing a Dense Measurable Subset in [0,1]
  • Thread starter Thread starter quantumdude
    Measurable
The problem involves constructing a measurable set E within the interval [0,1] such that both E and its complement in [0,1] are dense in [0,1], while also ensuring that the measure of E is greater than 0 but less than 1.
  • Participants discuss the challenge of including both rational and irrational numbers in the set E while maintaining the required properties of density and measure. There are attempts to explore the implications of adding or removing points from dense sets.
The discussion is ongoing, with participants exploring various strategies for constructing the set E. Some hints have been provided regarding the separation of the interval [0,1] into parts, but there is no explicit consensus on the approach yet.
Participants note that the problem excludes trivial examples and emphasizes the need for both subsets to be dense in [0,1]. There is also a recognition of the complexity involved in ensuring the measure conditions are satisfied.
quantumdude
Staff Emeritus
Construct a measurable set [itex]E\subset [0,1][/itex] with [itex]0<m(E)<1[/itex] such that both [itex]E[/itex] and [itex][0,1]-E[/itex] (that's a set difference) are dense in [itex][0,1][/itex].
None.
Well, the obvious dichotomy here is rationals vs. irrationals, but of course the rationals are countable and hence have measure zero, so that's no good. So now I'm thinking about including [itex]\mathbb{Q}\cap [0,1][/itex] in [itex]E[/itex], plus a selection of irrationals. Unfortunately, I can't think of how to pick the irrationals to go in [itex]E[/itex] without screwing up the denseness of the irrationals.
I have the feeling that this is one of those questions where you either see the trick, or you don't.
I don't. :cry:
I don't understand why you've got "...and [0,1] are dense in [0,1]" is there an extra condition?
That said, in response to:
"Unfortunately, I can't think of how to pick the irrationals to go in [itex]E[/itex]. Reload this page in a moment. without screwing up the denseness of the irrationals."
I have to ask, "Is it ever possible to add points to a dense set, and make that set not dense?"
Sorry, that was a typo. It's fixed now. The condition is that both [itex]E[/itex] and its complement in [itex][0,1][/itex] must be dense.
I wasn't thinking of adding points to the irrationals, I was thinking of taking points away from them and adding them to the rationals, in such a way that I get two sets with nonzero measure. Am I totally off base in thinking that way?
I remember seeing this question asked here before. If you get desperate, you can always browse the forums.
Not necessarily, since this is a rather open-ended question. That said, it's usually easier to operate in terms of intervals since it can be tricky to prove that a particular point set is measureable.
Hint: One way to construct an example is to separate [itex][0,1][/itex] into two intervals.
That doesn't sound right. Both subsets of [itex][0,1][/itex] have to be dense, and the conditions are rigged so as to exclude the trivial examples (such as choosing [itex][0,1)[/itex] and [itex]\{1\}[/itex], for instance). So if I choose two intervals, say [itex][0,a][/itex] and [itex](a,1][/itex] with [itex]a\in (0,1)[/itex], there will be neighborhoods in [itex][0,1][/itex] that do not contain points in one interval or the other (hence, neither will be dense in [itex][0,1][/itex]).
Tom Mattson said:
That doesn't sound right. Both subsets of [itex][0,1][/itex] have to be dense, and the conditions are rigged so as to exclude the trivial examples (such as choosing [itex][0,1)[/itex] and [itex]\{1\}[/itex], for instance). So if I choose two intervals, say [itex][0,a][/itex] and [itex][a,1][/itex] with [itex]a\in (0,1)[/itex], there will be neighborhoods in [itex][0,1][/itex] that do not contain points in one interval or the other (hence, neither will be dense in [itex][0,1][/itex]).
I'm sorry, that wasn't phrased as well as it could have been. I meant that you think of [itex][0,1][/itex] as two intervals and treat each interval differently.
I'm still not following you. What does, "think of [0,1] as two intervals" mean, if not splitting it up into two intervals such that [0,1] is covered by them?
Oh, I see it! :x
you were on the right track with those rationals and irrationals... now add nate's hint about "splitting [0,1] in two.. as in "[0,½) and (½,1]"
I assume you mean [0,1/2) and [1/2,1], since one subset is to be the complement of the other, right?
Even so, I must be missing something that is obvious to you guys. If I split up the interval like that, then I run into the problem that I described a few posts ago: Neither of those is dense in [0,1], as there are neighborhoods of [0,1] that don't contain any points of one or the other of those intervals.
Let's say that I take each of [itex][0,\frac{1}{2}) [\frac{1}{2},1][/itex] and split them into their rational and irrational components...
Ah, I think I see. The following would be a valid construction for [itex]E[/itex] then.
* Take [itex]\mathbb{Q} \cap [0,1/2)[/itex]
* Take [itex](\mathbb{R}-\mathbb{Q}) \cap [1/2,1][/itex].
* Take the union of the above.
Right, and you should be able to show that all the specified criteria are met.
Thank you both.
