TTL floating input ?
by mkbh_10
Tags: floating, input
mkbh_10
mkbh_10 is offline
#1
Mar4-08, 01:08 PM
P: 220
Why floating input is considered as HIGH in TTL based logic ckts ?
Phys.Org News Partner Engineering news on Phys.org
Fiber-optic microscope will help physicians detect cancer, diseases at early stages
Wind tunnel tests support improved aerodynamic design of B61-12 bomb
Smart sensor technology to combat indoor air pollution
zeitghost
zeitghost is offline
#2
Mar5-08, 02:35 AM
P: 157
Long long ago, a TTL input (for a simple example the 7400) was the emitter of an NPN transistor.
The base of said transistor was pulled up to Vcc (typically 5V in those days) by a resistor inside the chip.
Grounding the input connected the emitter to 0V and turned the transistor on.
Leaving the input floating or connecting it to 5V (usually via a resistor) turned the transistor off.
You can find the schematic of a TTL gate in old datasheets.
Since the input was relatively low resistance, there were none of the problems of CMOS inputs where allowing the input to float is a definite no no...
Register to reply
Related Discussions
input Calculus & Beyond Homework 4
how to obtain 4 input or gate using 2 input gates? Introductory Physics Homework 3
plz, i need input General Discussion 4
Logic question, 3 input OR to 2 input OR Electrical Engineering 9
Looking for input on this General Discussion 4
