Can Euler's Method Be Used to Approximate Nonlinear Differential Equations?
  • Thread starter Thread starter Nusc
    Method
The discussion focuses on using Euler's method to approximate the solution of the nonlinear differential equation y''=2y'-y+x*exp(x) over the interval 0<=x<=2 with boundary conditions y(0)=0 and y(2)=-4, using a step size of h=0.2. The user proposes two initial guesses for y1 and y2, and outlines a method to find coefficients a and b to satisfy the boundary conditions. The discussion emphasizes the importance of selecting appropriate initial derivatives y1'(0) and y2'(0) to derive valid solutions to the ordinary differential equation (ODE).
  • Understanding of Euler's method for numerical approximation
  • Familiarity with ordinary differential equations (ODEs)
  • Knowledge of boundary value problems and their solutions
  • Basic calculus, including derivatives and exponential functions
  • Study the implementation of Euler's method in numerical analysis
  • Learn about boundary value problem techniques, such as the shooting method
  • Explore the stability and accuracy of numerical methods for ODEs
  • Investigate alternative numerical methods for solving nonlinear differential equations, such as Runge-Kutta methods
Students and professionals in mathematics, engineering, and physics who are working on numerical methods for solving differential equations, particularly those dealing with boundary value problems.
Nusc
y''=2y'-y+x*exp(x)
0<=x<=2 y(0)=0 , y(2)=-4, h = 0.2
Approximate the solution using Euler's method
So we'll have two guesses
y1''=2*y1'-y1'+x*exp(x)-x y1(0)=0,
y2''=2*y2'-y2'+x*exp(x)-x y2(0)=0,
y=a1*y1+a2*y2
So i need to find the coefficients
What boundary conditions do I require? y1'(0)=? y2'(0)= ?
Pick two random values for y1'(0) and y2'(0). This will give you two solutions to the ODE.
Then y = a*y1 + b*y2 is also a solution.
You know that y1(0)=0 and y(2) =0, so ay1(0)+by2(0)=0. So fix a = 1, and pick b such that y1(2) + b*y2(2) = y(2).
So b = (y(2) - y1(2)) / y2(2), where y1(2) and y2(2) are the result of shooting with arbitrary guesses for y1'(0) and y2'(0).
Okay so say if I choose y1'(0)=1 and y2'(0)=2
y'=ay1'+by2' =>
y'(0)=a*(1)+b*(2)=0
=> a=-2*b
y(2)=-(2*b)*y1(2)+b*y2(2)=-4
-2y1(2)+y2(2)=-4/b
y2(2)=-4/b +2y1(2)
b=(-4-y1(2))/(-4/b+2y1(2))
b(-4/b+2y1(2)=-4-y1(2)
=> 3by1(2)=0
b or y1(2) is 0.
This correct so far?
