Register to reply
Need help in determining formula for for fishing lure depth...
by jdub
Tags: depth, determining, fishing, formula, lure
Share this thread:
jdub
#1
Mar4-08, 10:42 PM
P: 3
I need help in determining trolling lure depth for fishing. I imagine this formula would have to take into account line length, lure weight, and boat speed. I'm no math wiz, so if someone can help, It would be greatly appreciated!
Thanks.
Phys.Org News Partner Physics news on Phys.org
Step lightly: All-optical transistor triggered by single photon promises advances in quantum applications
The unifying framework of symmetry reveals properties of a broad range of physical systems
What time is it in the universe?
TVP45
#2
Mar5-08, 07:40 AM
P: 1,127
And whether you use a downrigger and how you adjust the lure. I can't imagine how you would put all that in a formula. Maybe some kind of nomograph would be the way to go.
Danger
#3
Mar5-08, 07:31 PM
PF Gold
Danger's Avatar
P: 8,964
Jeez, how to take the fun out of fishing!
If you're going to such extremes, why not just mount a bottom-scanning sonar unit on the lure? A huge part of the sport is knowing, and feeling where things should be. You'd might as well go with the old tried-and-true dynamite approach.
TVP45
#4
Mar6-08, 07:21 AM
P: 1,127
Quote Quote by Danger View Post
Did you ever think there might be a good reason for the RCMP watching you?
Danger
#5
Mar6-08, 08:40 AM
PF Gold
Danger's Avatar
P: 8,964
Quote Quote by TVP45 View Post
Never doubted it for a moment.
jdub
#6
Mar11-08, 04:26 AM
P: 3
Cause that costs money. No for real, I would like a basic formula to see what depth my lures are running at when trolling. Trust me, it doesn't take the fun out of fishing.
Danger
#7
Mar11-08, 09:29 AM
PF Gold
Danger's Avatar
P: 8,964
Sorry, Jdub; I misunderstood your original question. I thought that you were looking for a way to mechanically regulate the depth other than a simple 'bobber'.
I suspect that a formulae would be too complicated to bother with. There are a lot more factors involved than the ones that you mentioned. Water density, including salinity and temperature, would have a large impact, in conjunction with the hydrodynamic properties of the lure. Some lures that I have are made to dive deeper as they move faster, while most are the opposite. If you want just a rough idea based upon one particular lure, it might not be too bad.
I'm wondering if you could just rent a 'fish finder' sonar unit for a day or so and run some field tests tracking your lures at various speeds. Then you could print up a chart to carry around with you.
Register to reply
Related Discussions
Trouble Determining Moment of Inertia Formula Introductory Physics Homework 18
Setup help needed:apparent depth vs. actual depth Introductory Physics Homework 17
Help coming up with a formula for determining weight lost in cold. Biology 4
Actual Depth and Apparent Depth Introductory Physics Homework 19
Determining molecular formula Chemistry 4
