Thread Closed
Calculating Final Velocity
Share Thread Thread Tools
Mar5-08, 05:40 AM   #1
Question is a golf ball is dropped from a height of 78m assuming gravity is 9.8 m s, What is the velocity of the ball after the first 10m.
I assume the equation to use is [tex]v^2=u^2+2ax[/tex]
v = Final velocity
u = Initial Velocity
a = Acceleration
x = Displacement
So I plug in [tex]v^2 = 0+2(9.8ms)(10.0)[/tex]
Now according to the answer sheet V should be 14.0 m s but no matter how I plug this in I cant seem to get the right answer.
I think the problem is the way I am actually doing the math so if someone could perhaps step threw the maths so I can see where I went wrong.
Thanks for any help
2. Relevant equations
3. The attempt at a solution
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> 'Whodunnit' of Irish potato famine solved
>> The mammoth's lament: Study shows how cosmic impact sparked devastating climate change
>> Curiosity Mars rover drills second rock target
Mar5-08, 05:48 AM   #2
you shoudnt only learn about plugging values into the formula, you should learn the physical meaning of the formula!!!!!!!!!! THAT IS VERY IMPORTANT I got 14 using the EXACT equation above, I believe you have made a careless mistake.
Mar5-08, 05:48 AM   #3
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
No, no one can possibly tell you what you did wrong, because you haven't told us what you did! The equation you have, v2= 2*9.8*10 is correct and gives v= 14 m/s. Apparently you made a mistake in the arithmetic, although it seems rather elementary to me! Since you didn't show what you did or tell us what answers you got, I can't tell if it was something as simple as forgetting to take the square root.
Mar5-08, 05:53 AM   #4
How embarrassing, oerg you where spot on I forgot to take the square of the answer I think I have been working at this too long tonight .
Thanks Again
Thread Closed
Thread Tools
Similar Threads for: Calculating Final Velocity
Thread Forum Replies
Calculating the final velocity of a compressed-air launched projectile Introductory Physics Homework 4
Calculating Final Temp of a mixture Biology, Chemistry & Other Homework 1
Calculating final Velocity Introductory Physics Homework 3
Final Velocity Introductory Physics Homework 7
Final velocity Advanced Physics Homework 5
