Thread Closed
Electric potential in relation to electric field problem
Share Thread Thread Tools
Mar5-08, 01:52 PM   #1
The electric potential in a region of uniform electric field is -1000 V at x = -0.900 m and + 1400 V at x = + 2.00 m. What is E_{x} ?
2. Relevant equations
e=kq1q1/r^2
v= integral of E dot ds
v=ed
3. The attempt at a solution
i am thinking i will use the equation V=Ed, so I would use V=-1000 and d equal to -.9m
then i have no idea what to do from there, any help is appreciated. thank you
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Galaxies fed by funnels of fuel
>> The better to see you with: Scientists build record-setting metamaterial flat lens
>> Google eyes emerging markets networks
Mar5-08, 05:21 PM   #2
Recognitions:
Homework Helper Homework Help
Quote by gallib View Post
i am thinking i will use the equation V=Ed, so I would use V=-1000 and d equal to -.9m...
This is the right direction. For a potential which only changes along one dimension, you can write E = -dV/dx ; that is, the magnitude of the field is the slope of the potential function and the direction of the field runs from higher to lower potential. (This is basically where V = Ed comes from, for the case of a uniform field.)
BTW, in that formula, d is the separation between the two points over which the potential change is measured, not a position.
So you have two values of the electric potential at two values of x. What is the slope of this (linear) function? What is the direction of the electric field?
Thread Closed
Thread Tools
Similar Threads for: Electric potential in relation to electric field problem
Thread Forum Replies
Need help with electric field/potential problem Introductory Physics Homework 2
Electric Field/Electric Potential (Gradient Notation) Introductory Physics Homework 4
Calculating the Electric Potential from an Electric Field problem Introductory Physics Homework 1
Zero Electric potential and null electric field Introductory Physics Homework 1
Calculating Electric Potential in A Uniform Electric Field Introductory Physics Homework 4
