Calculating Area of Polar Function: Spiral r = 5(e^.1θ)
The problem involves calculating the area of a region defined by the polar function r = 5(e^.1θ), specifically focusing on the area in Quadrant I that lies outside the second revolution and inside the third revolution of the spiral.
  • Exploratory, Assumption checking
  • Participants discuss how to determine the bounds for the area calculation, questioning whether to set the equation equal to zero and exploring the ranges of θ for the second and third revolutions of the spiral.
The discussion is focused on clarifying the ranges of θ for the second and third revolutions, with some participants confirming the identified bounds and others seeking further validation of their understanding.
Participants are navigating the specifics of polar coordinates and the implications of defining revolutions in terms of θ, with an emphasis on ensuring the correct interpretation of the problem's requirements.
klarge
1. Problem: Use the spiral r = 5(e^.1θ). Find the area of the region in Quadrant I that is outside the second revolution of the spiral and inside the third revolution.
2. Homework Equations :
3. Attempt at solution:
My problem with finding the area of a polar graph is determining the bounds, so to get the right bounds for this graph do I set the equation equal to zero? I am really at a loss as to how to set up the bounds. Any hints would be helpful.
So... the second revolution is between which values of [itex]\theta[/itex] and the third is between which values of [itex]\theta[/itex]? [itex]\theta = 0[/itex] is the start of the first.
2nd between -2pi and 2pi and the third between -4pi and 4pi?
One full revolution is [itex]2\pi[/itex] radians. If revolution 1 is for [itex]0 < \theta < 2\pi[/itex] and the second revolution starts at [itex]\theta = 2\pi[/itex] radians and spans [itex]2\pi[/itex] subsequent radians, the second revolution has what range of [itex]\theta[/itex]?.
[itex]2\pi < \theta < 4\pi[/itex]
and the third would be [itex]4\pi < \theta < 6\pi[/itex].
Correct.
So the bounds would be between [itex]2\pi < \theta < 4\pi[/itex]?
