Calculating Angle and Magnitude of Vector Sum A+B+C and -A-B+C | Unit Vectors HW
The discussion revolves around calculating the angle and magnitude of vector sums involving three vectors A, B, and C, as well as their negative counterparts. The subject area is vector mathematics, specifically focusing on vector addition and trigonometric relationships.
  • Participants discuss adding vectors component-wise and drawing resultant vectors to visualize angles. There are questions about the correct application of trigonometric functions to find angles and magnitudes, with some uncertainty regarding arithmetic calculations.
Participants are actively engaging with the problem, sharing their attempts and clarifying concepts. Some guidance has been provided regarding the use of inverse tangent for angle calculations and the importance of accurately determining vector components. There is a recognition of potential arithmetic errors in the calculations.
There is mention of a specific angle being expected as 90 degrees, and confusion regarding the calculations leading to that conclusion. Participants are also exploring the implications of connecting vectors in a diagrammatic representation.
chocolatelover
Vector A=(oi +3j), B=(8i-1j), C=(-8i+5j)
Find the angle from the positive x-axis of the vector A+B+C
Find the magnitude and direction of the vector -A-B+C
I know that the answer is 90, but I'm not sure how to get that. I know that theta=tan-1(y/x) and that doesn't equal 90.
As far as the second part, this is what I did:
square root (0-8-8)^2+(-3+1+5)^2 and that supposed to be equal to 16.28, but it's not. Would I use tangent to find the angle?
Could someone please show me how to do this?
Thank you very much
For your first problem, add the three vectors together component by component, and draw the resultant vector. What is y? What is x? What is tan-1(y/x)? Just from the drawing, can you see that the angle is 90 degrees?
For your second problem, you have the right equation, and it does give 16.28. You would use inverse tangent to find the angle.
Thank you very much
Rx=0 and Ry=7(3-1+5), right?
So, x would be 0 and y would 7, right?
For the diagram, would you connect B to C?
For the angle are you just looking at the angle formed by the x-axis and vector A?
Thank you
Well, you are looking for the angle formed by A + B + C, which would be 0i + 7j, as you found.
Thank you very much
Now I see. Could you please show me how to do the second part?
Thank you
You have the right magnitude for the second part; you just must have made an arithmetic error. As for angle, you do have to use inverse tangent, which should be fine since you have i and j of the resultant vector (which you used to find magnitude).
Thank you
Wouldn't it be tan-1(9/264)? but that's 178
  • · Replies 26 ·
  • · Replies 18 ·
