Proving the Second Derivative Using Limit Definition
  • Context: Undergrad
  • Thread starter Thread starter mathishard
    Derivative
The discussion revolves around proving the second derivative of a function using its limit definition. Participants explore various approaches to derive the expression for the second derivative, addressing both theoretical and mathematical reasoning aspects.
  • One participant seeks help in proving that if a second derivative exists at a point, it can be expressed as a limit involving the function values at that point and its neighbors.
  • Another participant suggests manipulating the limit expression by factoring out terms and rewriting the fraction to facilitate the proof.
  • A different approach is proposed, where a new function is defined to explore the derivative of the first derivative, leading to a limit expression for the second derivative.
  • Some participants express confusion regarding the definition of the function used in the proof, questioning whether it remains constant or varies with respect to its arguments.
  • Concerns are raised about the relationship between the variables involved, particularly how the distance 'h' relates to the points 'x' and 'x0'.
  • One participant mentions the potential use of the Mean Value Theorem in the proof, indicating a desire to understand how it might apply.
  • Another participant provides a method involving two limits to derive the second derivative, suggesting a more complex approach to the proof.
Participants express varying levels of understanding and confusion regarding the proof, with no consensus on the best approach or the clarity of the definitions used. Multiple competing views on how to structure the proof and the role of limits remain evident.
Some participants note the need for clarity on the definitions and relationships between variables, highlighting potential ambiguities in the proof structure and the use of limits.
mathishard
2nd derivative proof..help please?
:confused:
hi, this will be my first post on the forum, although i in the past have looked over it!
um, this is NOT a homework problem, but is a problem in my textbook that i attempted to do.
it asks to show that if , for a function f, a second derivative exists at x0
to prove that
f''(x0) = lim h->0 [f(x0+h)-f(x0-h)-2f(x0)] / h^2
...At first i thought this would be easy, just using
f ' (x0) = limh->0 ( f(x0+h)-f(x0)) / h
and f''(x0) = lim (f'(x0+h)-f'(x0))/h
but somehow i haven't been able to get the expression they ask for? am i missing something?? (a trick)? thanks!
Try this...pull a 1/h to the outside, and consider how you might be able to rewrite the fraction as two more useful fractions added together (or subtracted).
or you might want to think like this : since f'(xo) exists, it means that
[tex]f'(x_o) = \lim_{h\rightarrow\ 0}\frac{f(x_o+h)-f(x_o)}{h}[/tex] , now let
[tex]F(x)=\frac{ f(x_o+h)-f(x_o)}{h}[/tex], let's try to find F'(x)
so
[tex]f''(x)=F'(x)=\lim_{h\rightarrow\ 0} \frac{F(x_o+h)-F(x_o)}{h}=\lim_{h\rightarrow\ 0} \frac{\frac{f(x_o+2h)-f(x_o+h)}{h}-\frac{f(x+h)-f(x)}{h}}{h}=\lim_{h\rightarrow\ 0}\frac{f(x_o+2h)-2f(x_o+h)-f(x_o)}{h^{2}}[/tex]
now let
[tex]h=x-x_o=>x_o=x-h[/tex] so we get
[tex]\lim_{h\rightarrow\ 0} \frac{f(x-h+2h)-2f(x-h+h)-f(x-h)}{h^{2}}=\lim_{h\rightarrow\ 0}\frac{f(x+h)-2f(x)-f(x-h)}{h^{2}}[/tex], this way we have found that the second derivative at any point x, and also at xo is:
[tex]f''(x)=\lim_{h\rightarrow\ 0}\frac{f(x+h)-2f(x)-f(x-h)}{h^{2}}[/tex]
hence for [tex]x=x_o[/tex] we have
[tex]f''(x_o)=\lim_{h\rightarrow\ 0}\frac{f(x_o+h)-2f(x_o)-f(x_o-h)}{h^{2}}[/tex]
P.S. Nice problem!
I'm a bit confused...
[tex]F(x)=\frac{ f(x_o+h)-f(x_o)}{h}[/tex] but doesn't that make F(x) a constant for all x?
Sorry to bring up a dead thread but I was actually wondering this as well.
No that equation is a standard one to get the derivative of any function using the first principle.
Btw how do you guys get those latex or whatever images into your answers?
But [tex]x_o[/tex] is just some point isn't it? It's not a variable.
Also how is [tex]h=x-x_o=>x_o=x-h[/tex] determined?
To put latex into posts it's just tex and /tex in brackets
It would have been better to write
[tex]F(x_0)= \lim_{\stack h\rightarrow 0}\frac{ f(x_0+h)-f(x_0)}{h}[/tex]
or
[tex]F(x)= \lim_{\stack h\rightarrow 0}\frac{ f(x+h)-f(x)}{h}[/tex]
Ah that makes a bit more sense, however I'm still not seeing the relationship between h, xo, and x that is used...
well h is the distance from x_0 to any point x.
Oh ok, that was sort of what I was thinking. In my class we've always used points x and x+h to define the derivative, that's why I was a bit confused.
I know this is an old thread, but hoping someone can clarify something. I can follow the proof from sutupidmath. But in the proof, I'm thinking there should be two distinct limits working in the equations, one because the definition for F(x) should contain it (as HallsofIvy defined it later), and then again to define F'(x). How would the proof need to change to address the two limits?
I have seen other notes that suggest using the mean value theorem for this proof. Although I understand the MVT, I have not been able to see how to use it.
Thanks for any help.
I would do this.
[tex]f"(x)= \lim_{h\to 0}\frac{f'(x+h)- f'(x)}{h}[/tex]
But
[tex]f'(x+h)= \lim_{k\to 0}\frac{f(x+h+k)- f(x+h)}{k}[/tex]
and
[tex]f'(x)= \lim_{k\to 0}\frac{f(x+k)- f(x)}{k}[/tex]
Put those into the the first equation and simplify. Since those must be true for h and k approaching 0 in any way, take h= k.
Many thanks. Very helpful.
