Is C* Just a Name or Does It Hold Physical Significance in Rocketry?
  • Thread starter Thread starter Xishan
    Velocity
The discussion revolves around the term C*, often referred to as 'Critical Velocity' or 'Characteristic Velocity' in the context of rocketry. Participants explore whether C* has physical significance or if it is merely a nomenclature for a combination of constants related to rocket engine performance.
  • Technical explanation, Conceptual clarification
  • One participant questions the physical significance of the term C*, suggesting it may just be a name.
  • Another participant clarifies that C* is actually the characteristic velocity, which measures engine performance independent of the exhaust nozzle.
  • A further contribution indicates that C* can be expressed as a complex function involving gamma, the molecular mass of combustion products, and flame temperature.
  • A later reply acknowledges the correction from 'critical velocity' to 'characteristic velocity' and appreciates the explanation provided.
Participants appear to agree on the correct terminology of 'characteristic velocity' but do not reach a consensus on the broader physical significance of C* itself.
There are unresolved aspects regarding the implications of C* in terms of its dependence on various factors such as molecular mass and flame temperature, which may affect its interpretation.
Xishan
Critical Velocity?
I've often come up with the term C* also called 'Critical Velocity' in rocketry. Is there any physical significance attached to this term or its just a name given to a combination of some constant terms?
It's the characteristic velocity, not the critical velocity
The characteristic velocity is a way to measure engine performance independent of the exhaust nozzle.
It is defined as:
[tex]c*=\frac{A_t * p_0}{dm/dt}[/tex]
where
At is the area of the throat,
p0 is the chamber pressure
dm/dt is the mass flow of the propellant.
Just wanted to add:
With a lot of re-arranging, it is a (complicated) function of gamma, the molecular mass of the combustion products, and the flame temperature.
yes ofcourse! I meant 'characteristic velocity' rather than 'critical velocity' and thanks for the brief but still good explanation
  • · Replies 40 ·
  • · Replies 17 ·
  • · Replies 47 ·
