Find Laplace Transform of (e^t + 2t^4 - cos (4t) + 10)
The discussion revolves around finding the Laplace Transform of the expression (e^t + 2t^4 - cos(4t) + 10) and includes related problems involving Laplace Transforms and their applications in solving initial value problems. The scope includes mathematical reasoning and technical explanations.
  • Homework-related
  • One participant requests the Laplace Transform of the expression (e^t + 2t^4 - cos(4t) + 10).
  • Another participant explains that the Laplace Transform is linear and suggests breaking the expression into separate terms to simplify the calculation.
  • A participant expresses uncertainty about how to apply the linearity of the Laplace Transform to the problem and requests further clarification.
  • Further clarification is provided, reiterating the use of linearity to separate the terms for calculation.
  • One participant proposes a solution for the Laplace Transform, presenting a formula that includes terms for each component of the original expression.
  • Another participant agrees with the proposed solution, indicating they arrived at the same result.
  • Subsequent posts introduce additional Laplace Transform problems, with one participant asking for verification of their solutions to these problems.
  • Responses to the additional problems include both agreement on one solution and disagreement on another, with detailed calculations provided for the verification process.
There is some agreement on the approach to solving the original Laplace Transform problem, but uncertainty remains regarding the application of the method. Additionally, the later problems introduced lead to mixed responses, with some solutions being accepted and others contested.
Participants express varying levels of understanding and confidence in applying the Laplace Transform, with some calculations remaining unresolved or requiring further clarification. The discussion includes multiple problems, each with its own complexities and assumptions that are not fully resolved.
This discussion may be useful for students or individuals studying differential equations and Laplace Transforms, particularly those seeking to understand the application of linearity in transforms and the verification of solutions to related problems.
Lucy77
Find Laplace Transform of...
Thank you
Remember that the Laplace Transform is a linear operator. That means that you can treat each one of the four terms as a separate little problem and then add them all back up at the end.
Other than that, just apply the definition of the Laplace Transform or look at a table of transforms.
cookiemonster
But I don't know how to apply what you said to this problem. Can you please show me how?
He meant that when calculating:
L{et+2t4-cos(4t)+10},
you can use the fact that the Laplace operator is linear to get:
L{et}+2L{t4}-L{cos(4t)}+L{10}.
That is, you can use linearity to turn your big problem into 4 small ones.
edit: fixed a superscript bracket
Is this right
e
1/(s-1) + 2* 4!/s^5- s/(s^2+16) + 10/s
am I done?
Thanks
I get the same thing.
Hi I just did two more Laplace problems can anyone please tell me if they're correct.
1.Solve the following intital value problem using the method of Laplace transforms.
y'' - 10y' + 25y = e^5t y(0)=0 y'(0)=0
y"- 10y'+ 25y= e5t becomes -y'(0)- sy(0)+ L(y)- 10f(0)+ 10L(y)+ 25L(y)= L(e5x).
Since y'(0)= y(0)= 0, this is just 34L(y)= L(e5x) so that
L(y)= L(e5x)/34 and, since L(cf)= cL(f) for any constant c,
y(x)= e5x/34.
2.Find Laplace transform inverse
L^-1 (4/s + 1/(s-1)^2 + (3s-16)/(s^2+64)
4 +te^t + 3cos8t + -2sin8t
Thank you
Number 2 is right.
Number 1 isn't.
[tex]L \{y^{\prime \prime}\} -10L \{y^\prime\} + 25L \{y\} = L \{e^{5t}\}[/tex]
[tex]s^2Y(s) -sy^\prime(0) - y(0) -10(sY(s) -y(0)) +25Y(s)= \frac{1}{s-5}[/tex]
[tex]s^2Y(s) -10sY(s) +25Y(s)= \frac{1}{s-5}[/tex]
[tex]Y(s)(s^2 -10s +25)= \frac{1}{s-5}[/tex]
[tex]Y(s)(s-5)^2= \frac{1}{s-5}[/tex]
[tex]Y(s)= \frac{1}{(s-5)^3}[/tex]
[tex]L^{-1}\{Y(s)\}=L^{-1} \{\frac{1}{(s-5)^3}\}[/tex]
[tex]y(t)=\frac{1}{2}t^2e^{5t}[/tex]
The above should be correct.
Well anyway, good Luck and I hope it helps.
Hi,
I have a couple of more that I did. Could someone please check and see if these are right.
1. FIND THE LAPLACE Transform of the unknown solution function for the following initial value problem:
y" + 4y' - 5y = te^(t), y(0) = 1, y'(0)=0
(Do Not actually find the function, only its transform. Then, without carrying out the steps, inidicate briefly how you would proceed to find the solution function.)
s^2L = s + 4sL - 4 - 5L = Lte^t = 1/(s-1)^2
(s^2 + 4s - 5)l = 1/(s-1)^2 + s +4 = (s^3+ 2s^2-7s+4)/(s-1)^2
simplify
= (s-1)^2(s+4)/(s-1)^3(s+5) = s=4/(s-1)(s+5)
at this point I would do partial fractions.
2.Find Laplace Inverse
L^-1 { (s+10)/(s^2+8s+20)}
s+10)/(s^2+8s+20) = (s+10)/(s^2+8s+16+4) = (s+10)/((s+4)^2+4)
(s+10)/((s+4)^2+4) = (s-(-4))+ 3*2)/(s-(-4))^2+2^2) = (s-(-4)/((s-(-4))^2+2^2) + 3*2/(s-(-4)+2^2)
The Inverse Laplace Transform of that is
e^-4t cos 2t + 3 e^-4t sin 2t.
3. Find Laplance Transform
Find L (f(t)} where f(t) = e^-t (0 <= t < 5)
-1 (t >= 5)
For t in [0,5) the solution would be Int((e^{-t})(e^{-st},0,infinity,dt)=Int(e^{-t(s+1)},0,infinity,dt}=-e^{-t(s+1)}/(s+1)|0,infinity) = 1/(s+1).
For t in [5,infinity) Int(-1*e^{-st},0,infinity,dt} =(1/s)e^{-st}|0,infinity)=-1/s.
In piecewise notation you write L(f(t))={1/s, 0 <= t < 5 and -1/s, t >= 5}
4. Find Laplace Inverse of
L^-1 { (3s-4)/s(s-4) }
so
3s-4)/s(s-4) = A/s + B/(s-4)
s*(3s-4)/(s(s-4)) = A + B*s/(s-4)
Taking limit ( s to 0)
-4/-4 = A
A =1
And
(s-4)*(3s-4)/(s(s-4)) = A*(s-4)/s + B
Taking limit ( s to 4)
8/4 = B = 2
so
(3s-4)/s(s-4) = 1/s + 2/(s-4)
Thank you
  • · Replies 17 ·
