Calculating G from landing Aircraft
  • Context: Undergrad
  • Thread starter Thread starter jkl
    Aircraft
This discussion focuses on calculating the landing G load of modern jet aircraft, specifically addressing the deceleration rates during landing. A typical descent rate of 200 feet per minute results in a G load of approximately 0.13 g, while a heavier landing at 700 feet per minute yields a significantly higher G load. The calculations utilize a landing weight of 55,000 kg and an approximate strut compression of 40 cm. The methodology involves applying the equation for uniform acceleration to derive the G load based on descent rates and braking distances.
  • Understanding of basic physics principles, particularly uniform acceleration
  • Familiarity with the metric system and SI units
  • Knowledge of jet aircraft landing dynamics
  • Ability to perform calculations involving G forces and deceleration rates
  • Research the physics of landing dynamics in aviation
  • Learn about the impact of strut compression on G loads during landing
  • Explore advanced calculations for varying descent rates in different aircraft types
  • Investigate the effects of environmental factors on landing performance
Aerospace engineers, flight performance analysts, and aviation enthusiasts interested in the mechanics of aircraft landings and G load calculations.
jkl
Hopefully I have posted this in the correct section;
Can anyone help with the equation(s) & assumptions required to specifically calculate the landing G load of a modern jet aircraft.
I'm trying to calculate the G deceleration rate of an aircraft on landing based on the initial vertical descent rate on landing in feet per minute. For example a typical jet aircraft landing would give a decent rate around 200 feet per min at impact & a heavy landing would be around 700 feet per minute at impact so I want to find out the G load of the two.
Typical landing weight of 55,000kg & strut compression around 40cm as an approximation as it will vary with impact force. Also typical speed of 130kts at landing.
Looking for a simple way to start with decent rate in feet per minute & depending on certain assumptions, still air, strut compression, temperature & other assumptions arrive at the landing G load/impact force
cheers
Use SI units. 200 ft/min are roughly 1 m/s. If the acceleration during the 40 cm braking distance is uniform then we can calculate the acceleration via s=1/2 a t2 = 1/2 v2/a or a=1/2 v2/s. Plugging in 1 m/s and 0.4 m gives 1.25 m/s2. 1g is about 10 m/s2 so 1.25 m/s2 is about 0.13 g. A very gentle deceleration. With 700 ft/min you'll get a much larger value.
  • · Replies 29 ·
10K
  • · Replies 0 ·
