| Thread Closed |
Radiation by an accelerated electron? |
Share Thread |
| Mar14-08, 05:00 AM | #1 |
An isolated electron (magnetic moment mu) in motion in a uniform
magnetostatic field of magnitude, B, has a potential energy, U, within the range -mu B < U < mu B. If U is not at its minimum value the electron is precessing. One would expect the potential energy level to have some effect on the rate at which the electron loses energy by radiation. But classical electrodynamics (Jackson p 469) asserts that the power radiated is determined only by the acceleration of the electron. It would seem reasonable to assume that if U is a minimum (no precession) the electron is in a stationary state and the power radiated is exactly zero. Is there any experimental evidence against this assumption? Phil Gardner |
| Mar14-08, 05:00 AM | #2 |
On 2008-03-13, Phil Gardner <pej_dg@dodo.com.au> wrote:
> An isolated electron (magnetic moment mu) in motion in a uniform > magnetostatic field of magnitude, B, has a potential energy, U, within > the range -mu B < U < mu B. If U is not at its minimum value the > electron is precessing. > > One would expect the potential energy level to have some effect on the > rate at which the electron loses energy by radiation. But classical > electrodynamics (Jackson p 469) asserts that the power radiated is > determined only by the acceleration of the electron. Spin is a quantum phenomenon and is not accounted for by the classical theory of the electron. Thus the conclusion given by Jackson is correct, though up to quantum corrections which should depend on spin. > It would seem reasonable to assume that if U is a minimum (no > precession) the electron is in a stationary state and the power > radiated is exactly zero. Is there any experimental evidence against > this assumption? Why should you make an assumption? There are models of an electron coupled to radiation that can give an answer directly (QED a fortiori, but perhaps also some simplified models). A stationary state, by definition, implies that there will be no emission of radiation (which is a dynamical process). Is your question perhaps whether minimization of U garantees the identification of the ground state (a state particularly unlikely to radiate)? Quantum mechanics dictates that the ground state is identified by minimizing the total energy (the Hamiltonian, to be precise), which includes *both* the potential and kinetic energies. And yes, this result has been extensively verified experimentally. Hope this helps. Igor |
| Mar15-08, 05:00 AM | #3 |
On Mar 13, 3:47 pm, Phil Gardner <pej...@dodo.com.au> wrote:
> An isolated electron (magnetic moment mu) in motion in a uniform > magnetostatic field of magnitude, B, has a potential energy, U, within > the range -mu B < U < mu B. If U is not at its minimum value the > electron is precessing. > > One would expect the potential energy level to have some effect on the > rate at which the electron loses energy by radiation. But classical > electrodynamics (Jackson p 469) asserts that the power radiated is > determined only by the acceleration of the electron. > > It would seem reasonable to assume that if U is a minimum (no > precession) the electron is in a stationary state and the power > radiated is exactly zero. Is there any experimental evidence against > this assumption? > > Phil Gardner Well, magnetic field doesn't move things I think. Its a change in orientation. However, I'd ask if electrons radiate while falling down to earth. |
| Mar26-08, 05:00 AM | #4 |
On Mar 13, 9:47am, Phil Gardner <pej...@dodo.com.au> wrote:
> It would seem reasonable to assume that if U is a minimum (no > precession) the electron is in a stationary state and the power > radiated is exactly zero. Actually, it's not reasonable. One takes the potential for a point source to be that obtained by transforming the static potential to a moving frame. However, an important proviso is that the source point is to be that where the source WAS located at that time in the past where its image would have come from. Thus, if the position the field is taken at is given by the vector r, and the source lies on a trajectory given by r(t) (also denoted by the letter r), then the separation from the field point r and the source point r(t) is given by R = r - r(T) where the time T is t, itself, with the light equivalent of the distance subtracted out: T = t - |R|/c. All of what I'm about to describe also has a classical analogue and there, too, there will be radiation terms involving the acceleration. But the expressions are quite a bit different and I won't bother with them here. The potential is given in the language of differential forms as A = (A_x dx + A_y dy + A_z dz - phi dt). I'll use the vectors dr = (dx, dy, dz); dS = (dy dz, dz dx, dx dy). So, the field is given by the 2-form F = E_x dx dt + E_y dy dt + E_z dz dt + B_x dy dz + B_y dz dx + B_z dx dy = (E.dr) dt + B.dS. The usual convention with forms is that dx dy = -dy dx, dx dx = -dx dx = 0, etc. Thus, one can write dS = 1/2 dr X dr where X denote the vector product. Thus, one can form products (a.dr) (b.dr) = (aXb).dS = -(b.dr) (a.dr) (a.dr) (b.dS) = (a.b) dV = (b.dS) (a.dr) where dV = dx dy dz. Using the relation F = dA, the field can be calculated in a direct fashion. Mostly, this comes down to the somewhat routine matter of expressing the differentials of R, |R| and T in terms of dr and dt. Indeed, one can write dT = dt - 1/c d|R| dR = dr - v dT d|R| = R.dR/|R| where ().() denotes the dot product. The velocity is that taken at time T; v = r'(T). Solving for dT, dR and d|R|, one obtains dT = (|R|cdt - R.dr)/(|R|c - R.v) dR = (Rc (dr - v dt) + R X (v X dr))/(|R|c - R.v) d|R| = Rc.(dr - v dt)/(|R|c - R.v). The potential 1-form fitting the description provided above is given by A = (mu_0/4pi) ec (v.dr - c^2 dt)/(|R|c - R.v). Immediately, you can see that differentiating it will yield something involving the acceleration. In particular, d(v.dr - c^2 dt) = v'(T). dT dr - d(dt) = -a(T).dr dT, making use of the property d(dt) = 0. Substituting in dT, one gets d(v.dr - c^2 dt) = a.dr (R.dr - |R|c dt)/(|R|c - R.v) = ((a X R).dS - |R|ac dr dt)/(|R|c - R.v). = a.(R X dS - |R|c dr dt)/(|R|c - R.v). Working out the algebrain a similar way, one gets d(|R|c - R.v) = c d|R| - v.dR - R.a dT. After substituting for d|R|, dR and dT, and doing a little vector algebra, ultimately one gets d(|R|c - R.v) = (c^2 - v^2 + R.a) (R.dr - |R|c dt)/(|R|c - R.v) - (v.dr - c^2 dt). So, here, too, there is an acceleration involved. Multiplying on the right by (v.dr - c^2 dt) the last term cancels out. The product with the first term is obtained via (R.dr - |R|cdt)(v.dr - c^2 dt) = R X v.dS + c(|R|v - Rc).drdt = (|R|v - Rc).(Rc dr dt - R X dS). Combining these results, and using a little more vector algebra, one gets for the field strength F = (mu_0 c e/4 pi |R|) (K/(|R|c - R.v)^3).(|R|c dr dt - R X dS) where K = R X ((Rc - |R|v) X a) + (c^2 - v^2) (Rc - |R|v). The electric field is extracted out of this, E = (mu_0 c^2 e/(4 pi)) K/(|R|c - R.v)^3 B = R X E/|R|c. So, there is definitely a dependence on the acceleration. You can extract from this the (1/r) part and that is the radiation field. Even in the non-relativistic form of electrodynamics, there will be a radiation term, as mentioned before. |
| Thread Closed |
Similar discussions for: Radiation by an accelerated electron?
| Radiation reaction for a uniformly accelerated charge | General Physics | 2 | ||
| When does an accelerated electron not radiate? | Quantum Physics | 4 | ||
| accelerated electrons emitting radiation | Quantum Physics | 42 | ||
| why do accelerated charges emit e/m radiation? | General Physics | 1 | ||
