[101]Potential energy of mass on a spring with 2 givens
The discussion focuses on calculating the total potential energy (PE) of a 1.1 kg mass on a vertical spring with a maximum speed of 3 m/s. The key takeaway is that at the endpoints of its motion, all kinetic energy (KE) is converted into potential energy. The correct relationship is established as PE = KE, where KE is calculated using the formula KE = 1/2 mv². The participant initially miscalculated the energy but clarified that the total energy at the endpoints equals 3.3 J.
  • Understanding of simple harmonic motion
  • Knowledge of kinetic energy and potential energy equations
  • Familiarity with mass-spring systems
  • Basic algebra for manipulating equations
  • Study the principles of simple harmonic motion in-depth
  • Learn about energy conservation in mechanical systems
  • Explore the derivation of the spring constant and its effects on oscillation
  • Investigate real-world applications of potential and kinetic energy in spring systems
Students studying physics, particularly those focusing on mechanics and energy conservation, as well as educators looking for examples of potential energy in mass-spring systems.
WPCareyDevil
[SOLVED] [101]Potential energy of mass on a spring with 2 givens
A 1.1 kg mass vibrating up and down on the end of a vertical spring has a maximum speed of 3 m/s. What is the total potential energy of the mass on the spring when the mass is at either endpoint of its motion? NOTE: Assume that the potential energy of the mass on the vertical spring is zero when the mass is at the midpoint of its motion.
ME=KE+PE?
PE(tot)=PE(g)+PE(e)?
I am having a hard time figuring out how to attack this one... I have a graph of energy of a simple harmonic motion, which I understand. It makes sense to me that KE will be greatest and PE will be zero at its midpoint, and vice versa at the uppermost and lowermost part of its the motion. But without the spring constant or its length of travel, I can't get any further.
Can someone "light bulb" me?=P
Thank you so much for your help!
Well, the velocity is the fastest at the midpoint of the oscillation, where the potential energy is zero. When the velocity is zero, the spring is stretched at its maximum, the amplitude, so all of that kinetic energy that you had at the midpoint is now transferred into potential energy at the endpoints.
Thanks for the reply, I think I am getting warmer.
I figured the KE at the mid point would be the mass times its velocity (1.1kg * 3m/s = 3.3J), which much equal the PE. However, the 3.3J is incorrect...
and.. ah hah. I was trying to make things too difficult.
I should have just remembered PE=KE and KE=1/2mv^2
Thanks for the help!
  • · Replies 20 ·
19K
