How do functions and vector fields interact with normal derivatives?
The discussion revolves around the interaction between functions and vector fields with respect to normal derivatives, focusing on the mathematical properties and rules governing these interactions. Participants explore theoretical aspects, mathematical reasoning, and potential misconceptions related to vector calculus identities and operations.
  • Some participants express confusion about the interpretation of normal derivatives and the application of vector rules when dealing with functions versus constants.
  • There is a discussion about whether the normal derivative can be treated similarly to a scalar constant, with some arguing that it cannot due to the nature of functions.
  • Participants reference the identity for divergence, noting that div(fG) = f div G + (∇f) · G, and question how this applies when f is a function rather than a constant.
  • One participant points out a potential error in evaluating derivatives, emphasizing that the value of the derivative at a point is not the same as the derivative of the value at that point.
  • There is a debate over whether the operator ∇ can be applied directly to functions and whether it operates on both f and g in certain expressions.
  • Some participants clarify that while f is a scalar field, it is not a constant scalar field, which affects how it can be treated in mathematical operations.
Participants express differing views on the treatment of functions and constants in the context of normal derivatives and vector calculus. There is no consensus on the correct interpretation or application of the rules discussed, indicating that multiple competing views remain.
Limitations include the potential misunderstanding of the application of vector calculus identities, the distinction between constant and non-constant scalar fields, and the specific operations of the gradient operator on scalar and vector fields.
kingwinner
Suppose that normal derivative = [itex]\nabla[/itex]g . n = dg/dn,
then f [itex]\nabla[/itex]g . n = f dg/dn
[I used . for dot product]
But how is this possible?
For f [itex]\nabla[/itex]g . n, I would interpret it as (f [itex]\nabla[/itex]g) . n
But f dg/dn = f ([itex]\nabla[/itex]g . n) which is DIFFERENT (note the location of brackets)
I recall that if u,v are vectors, a is a scalar constant, then (au) . v=a(u . v) = u . (av), but in our case, f is a FUNCTION! So this rule cannot be applied.
f [itex]\nabla[/itex]g . n = f dg/dn seems to be suggesting that f is a scalar constant, but consider the following case:
Let div F=[itex]\nabla[/itex] . F
If f were really a scalar constant, then by the rule, div (f [itex]\nabla[/itex]g) = [itex]\nabla[/itex] . (f [itex]\nabla[/itex]g) = f ([itex]\nabla[/itex] . ([itex]\nabla[/itex]g)) which is WRONG because we know that in general div(fG)=f div G + ([itex]\nabla[/itex]f) . G where f is function and G is vector field. But if this is wrong, then HOW can you justify that (f [itex]\nabla[/itex]g) . n = f ([itex]\nabla[/itex]g . n)?
I seriously can't understand this...there are two seemingly contradicting ideas crashing in my mind...
Would someone be nice enough to clear my doubts? Thanks!
Remember that two scalar fields are equal if and only if they have the same value at every point! What happens if you evaluate both [itex](f \nabla g) \cdot \vec{n}[/itex] and [itex]f (\nabla g \cdot \vec{n})[/itex] at a generic point x?
At every fixed point, f would be a scalar constant, so "the rule" can be applied, right?
But if we can treat f as a scalar constant, then by "the rule", div (f [itex]\nabla[/itex]g) = [itex]\nabla[/itex] . (f [itex]\nabla[/itex]g) = f ([itex]\nabla[/itex] . ([itex]\nabla[/itex]g)) which is WRONG because we know that in general there is an identity div(fG)=f div G + ([itex]\nabla[/itex]f) . G where f is function and G is vector field. Using this identity gives a different answer.
Note: "the rule": if u,v are vectors, a is a scalar constant, then (au) . v=a(u . v) = u . (av)
You made an error when evaluating the derivative, though. The value of the derivative of a function at a point is (usually) not the derivative of the value of the function at that point.
In particular...
[tex](\nabla \cdot f)(a) \neq \nabla \cdot f(a) \quad (= 0)[/tex]
Another example, for comparison:
[tex]f'(a) \neq f(a)'[/tex]
In particular...
Sorry, I don't quite get your point.
Can you please inform me where (which equal sign) exactly I am wrong?
Also, for your " f ", is it a scalar or a vector field?
What's the problem? All you have done is multiply the normal derivative by f. There's no differential operation on f at all so you do not need to be concerned that it is a function rather than a scalar.
Indeed. I think I am more stumped about why you are stumped than you are stumped about the problem at hand.
I was using f for scalar field, as you were. Note that these expressions would be nonsense if f were a vector field.
This is wrong -- you cannot simply pass f through the derivative. You need to use the chain rule.
You said that [tex](\nabla \cdot f)(a) \neq \nabla \cdot f(a) \quad (= 0)[/tex], but how can a vector be dotted with a scalar?
But if u,v are vectors, a is a scalar, then (au) . v=a(u . v) = u . (av)
Now [itex]\nabla[/itex] is a vector, f is a scalar, [itex]\nabla[/itex]g is a vector, so I just applied the above property, getting [itex]\nabla[/itex] . (f [itex]\nabla[/itex]g) = f ([itex]\nabla[/itex] . [itex]\nabla[/itex]g)
How come it works for the first case (normal derivative case), but not this one? This is the part I don't understand...
Thanks for explaining!
[tex]\nabla[/tex] not only a vector, but an operator as well. You can't just blindly apply vector rules, but you must apply derivative rules well.
[tex]\nabla \cdot (f\nabla g) \neq f (\nabla \cdot \nabla g)[/tex]
because it is operating on both f and g.
[tex](f\nabla g) \cdot (\vec{n}) = f(\nabla g \cdot \vec{n})[/tex]
because it is operating just on g.
You're right; I forgot about that example (and the example with f'). Those examples were a vector field and a function of the reals, respectively.
So for the first case, we need to use the product rule, right?
Yes.
Sorry, but something is still not perfectly clear to me...
Why is [tex]\nabla[/tex] operating on BOTH f and g for the first case?
If we could treat f as a scalar, we should be able to pull it out like a constant...
The operator [itex]\nabla \cdot[/itex] is not operating on either of them. It's operating on the vector field [itex]f \nabla g[/itex].
f is a scalar (field), but it's not a constant scalar (field). If you want to treat scalar fields like numbers, you have to distinguish between the constant scalars and the nonconstant scalars.
The point I made earlier was about evaluating the expression at a point. If I have the scalar field g given by (u and v are vector fields)
[tex]g = u \cdot v[/tex]
then what is the value of g at a point a? i.e. what is g(a)?
Now, if I instead have the scalar field
[tex]g = \nabla \cdot u[/tex]
For the first case, g(a)=(u.v)(a), just dot u with v to get an expression and substitute in the value a?
For the second case, g(a)=(del.u)(a) just do the dot product FIRST and then sub. in the value a? I can't see any difference... :(
One more related question:
(f . [itex]\nabla[/itex]) g
f . ([itex]\nabla[/itex]g)
Are these equivalent? If so, then why write in the fist form? My textbook keeps writing in the first form and I don't know why...
