Thread Closed
Want to build a home-made generator..
Share Thread
Mar20-08, 10:41 PM   #1
First off thanks for the quick replys on my first post. Now, I'm looking to build a home-made generator, i've been told that I can just reverse the motion of a electric motor and *poof* it becomes a generator, is this true? And I was also considering just using a automobile alternator as my generator, But at what RPM would the alternator have to spin to give off efficient charge to charge a 12v car battery?
PhysOrg.com engineering news on PhysOrg.com
>> Multiview 3-D photography made simple
>> Giant 3-D printed bugs shed light on insect anatomy
>> A microphone that listens with light
Dec6-08, 05:40 AM   #2
that is dependent on the strength of the magnets and how much flux is created by the alternator.
Unless you already have the details of the alternator, the best way is to just hook up an ammeter and volt meter and spin it yourself and take a few readings
Dec6-08, 05:50 AM   #3
Recognitions:
Gold Membership Gold Member
From a backyard mechanic/racer perspective, I would assume that spinning your alternator at the basic idle speed of an engine (450+rpm) should provide an adequate charging output. That should be between 13 and 14.5 volts.
Dec6-08, 07:01 AM   #4
Mentor
Quote by Danger View Post
.... taking into account whatever gear ratio (if any) is applied by the belts and pulleys.
Dec6-08, 08:32 AM   #5
Recognitions:
Also you need to provide voltage to the field windings before you can get an output. For most auto alternators.
Thread Closed
Similar discussions for: Want to build a home-made generator..
Thread Forum Replies
How do you build a home-made speaker using magnets, plastic, coils, etc.? Introductory Physics Homework 15
home made zapper? Classical Physics 7
Home-made nanomachines Atomic, Solid State, Comp. Physics 8
Home-made RC Hovercraft Mechanical Engineering 0
Home-made superconductors ? Atomic, Solid State, Comp. Physics 11
