| Thread Closed |
Newton's Bucket |
Share Thread | Thread Tools |
| Jul20-10, 08:46 PM | #137 |
Newton's Bucket |
| Jul21-10, 12:24 PM | #138 |
| Jul21-10, 10:59 PM | #139 |
@Buckethead: "Does light or gravity even propagate in a pre-big bang univserse?" There's no space in a pre-big bang universe, so no. "If Mach's principle holds, then it will head out toward whatever star it was pointing to when it was released and continue on to that star even if that star and all other matter in the universe moves out of position relative to "empty" space. If Mach's principle does not hold, then it will head out toward a star, but miss the star if the star (and all other matter) moves." There's no such thing as movement relative to empty space. If everything moves by the same amount then nothing moves. "In other words, the "straight" line will be straight in only one of those scenarios, but it is not clear which one. I'm a Machian person, so I think the object will follow the stars. Keep in mind that light will follow only one of these trajectories as well, so in either case the path of the object will be parallel to beam of light that is projected parallel to the initial path of the object when it is released, which is why it will look "straight" regarless of which path it is following." Why would it always look straight? Light doesn't, it always follows at least a slightly curved path, just not locally. |
| Jul22-10, 02:19 AM | #140 |
Indeed! Which makes me wonder why the debate about Mach's principle is still going on. Nevertheless it is, and (correct me if I'm wrong) the alternative to Mach's principle is acceleration relative to background spacetime (Minkowski spacetime?)? Sorry, but I can't say I really understand what is meant by acceleration relative to spacetime. This doesn't make much sense to me. |
| Jul22-10, 03:16 AM | #141 |
Issue more murky in GR as, inspired by Mach, Einstein designed GR so that inertial properties of space-time are not independent of distribution of matter. However, whether inertia can be reduced to properties of matter and distribution of matter in GR, as Mach would have liked, or whether there is rather just a weaker causal or lawlike relation between space-time structures and matter distributions, is still tricky. Empty solutions of GR and rotating universe solutions suggest Mach's principle not fully realised by GR, but there is some debate. |
| Jul22-10, 12:18 PM | #142 |
| Jul22-10, 12:49 PM | #143 |
Not sure I quite follow the question.
No properties? Space-time? Why do you say this? Quite a rich mathematical structure to Minkowski spacetime. Dimensionality, metrical properties, affine properties, topological properties - the question is the degree to which these properties can be understood as just coding the properties and relations of matter or fields. |
| Jul22-10, 01:53 PM | #144 |
My question, to be more clear, rests on my general concern that if the properties of spacetime are simply used to describe properties and relations of matter or fields (which makes total sense to me) and if a matterless universe results in space-time with no sensible properties, then space-time is intimately related to matter to such a degree that they can be said to be inseparable. If this is the case, then in your first paragraph, where you say space-time can take up the slack where acceleration cannot be grounded in matter, if matter and spacetime are inseparable the slack cannot simply be pawned off to space-time. With regard to GR, since GR is based on adding gravity (and/or inertia?) to the problem, and since gravity and inertia are dependent on matter, doesn't this again just reduce to space-time having no real properties once matter is out of the picture. Doesn't all of this just boil down to saying that inertia and the path that an object would take are 100% reliant on the matter in the universe? |
| Jul22-10, 02:42 PM | #145 |
In standard formulations of Minkowski spacetime, inertial lines are not defined in terms of the distribution of matter, and acceleration is absolute. There is no obvious guarantee that inertial lines can be defined in relational terms to matter distribution. I think 'the slack cannot simply be pawned off to space-time' needs to be justified. I don't believe one has a priori insight into whether or not there is space or spacetime. I would prefer an explanation that postulated only matter, but if it turns out that there are effects which cannot be explained in such a way, but which can be explained by taking space-time seriously, then I think it is rational to accept spacetime, much as we accept other theoretical entities. But this is an old and rich and interesting debate, and there are strong views on either side, so you are by no means alone here. |
| Jul23-10, 09:21 AM | #146 |
Just a thought . If all the matter in the universe is limited to the bucket and water wouldn't both acceleration and inertia simply apply as usual?? Certainly the concept of spacetime in the absence of matter is problematic in all cases. |
| Jul23-10, 09:33 AM | #147 |
If they are coding the properties of matter or fields than they would also seem to not apply in the absence of matter ,no? |
| Jul23-10, 09:49 AM | #148 |
And explain it as an emergant quality from the more fundamental property of gravity. Live and learn. I think to dismiss the whole question indicates a metaphysical or philo sophical view. |
| Jul24-10, 06:04 PM | #149 |
| Jul24-10, 07:01 PM | #150 |
In addition, if space-time can support inertial lines alone, then what is the mechanism? Obviously not gravity, but something. Is space-time a literal "grid" of inertial lines? What are these lines made of? A large self sustaining field of somekind? Some kind of new darker- dark matter? Now the thing is, I think I can go either way with this. I can be convinced that Mach's principle is wrong if it can be shown that space-time alone can describe inertial lines, or I can go with Mach's principle if it can be shown that space-time can describe inertial lines, but only as a result of the effect of matter on space-time. In either case, I don't think gravity is the mechanism. Also it should be noted, that I'm also saying that if Mach's principle holds, then this indicates that inertial lines might be undefined in an empty (or otherwise empty) universe. |
| Jul25-10, 02:04 AM | #151 |
| Jul25-10, 05:20 AM | #152 |
So basically Machs principle is that acceleration is just as relative as velocity? I'm not sure how acceleration would be possible in a one object universe. Space-time is a measurement of the distances between objects.
So an extension of this is that if there were more matter in the universe then everything would require more energy to accelerate, and obviously the reverse if there's less? |
| Jul25-10, 05:26 AM | #153 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Newton's Bucket
| Newton's bucket and Galilean relativity | Special & General Relativity | 7 | ||
| Newton's bucket problem | Introductory Physics Homework | 2 | ||
| Newton's bucket...absolute space???? | General Discussion | 18 | ||
| leaking bucket | General Physics | 5 | ||
| falling bucket | Introductory Physics Homework | 10 | ||
