| Thread Closed |
Pulley/Torque problem where pulley has mass |
Share Thread | Thread Tools |
| Mar21-08, 10:10 PM | #1 |
hi, im new to the forum =] my names suraj and im an engineering/journalism student in my first year. this forum looked pretty informative so i figured id sign up. anyways id really appreciate it if someone could help me out on this problem.
1. The problem statement, all variables and given/known data Consider two objects with connected by a light string that passes over a pulley having a moment of inertia of about its axis of rotation as shown in the figure below. The string does not slip on the pulley or stretch. The pulley turns without friction. The two objects are released from rest separated by a vertical distance . (a) Use the principle of conservation of energy to find the translational speeds of the objects as they pass each other. (b) Find the angular speed of the pulley at this time. 2. Relevant equations well not given in the problem but i believe you have to apply: -Free Body Diagrams (of both masses) -Torque=Fd -Kinematics 3. The attempt at a solution okay well i tried to solve it in the variable form that the question is asking for, and i was unable to do so. however i tried to plug in some numbers (give each mass a numerical mass, give the pulley a random mass, etc) and i believe i solved the problem. im just confused as to how i should solve it in the form using variables? this is what i got when i made up values for the pulley's mass, the pulley's radius, the mass of the weight on the left, and the mass of the weight on the right: http://i21.photobucket.com/albums/b2.../solution1.jpg however it is asking me the answer in terms of variables, and im having a hard time trying to find my acceleration in terms of variables so i can use the equation i ended up in the above solution (i figured that if i can solve for a in terms of variables, cant i just plug it into v=sqrt(2a*deltaY)?) http://i21.photobucket.com/albums/b2.../solution2.jpg thanks for the guidance |
| Mar21-08, 11:12 PM | #2 |
Hi Suraj!
In this pic, as [tex]m_1>m_2[/tex] the equations should be [tex]m_1g-T_1=m_1a[/tex] and [tex] T_2-m_2g=m_2a[/tex] The [tex]\tau=I\alpha[/tex] equation looks good to me. |
| Mar22-08, 07:16 AM | #3 |
You will have a loss in PE balanced by a gain in KE and work done.
What is it that loses PE, and by how much ? What are the gains in KE and by how much ? What work is done and how much ? |
| Mar22-08, 08:58 PM | #4 |
google_spider:
am i on the right track in finding the acceleration first, in terms of variables, and then plugging it into the equation (sqrt(2a*deltaY))? |
| Mar22-08, 11:13 PM | #5 |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Pulley/Torque problem where pulley has mass
| Time problem involving Mass and a Pulley? | Introductory Physics Homework | 1 | ||
| PLEASE HELP ME!!!! Pulley-Mass Problem | Introductory Physics Homework | 24 | ||
| Three mass pulley problem-Neat! | Introductory Physics Homework | 3 | ||
| SHM with mass over pulley problem | Introductory Physics Homework | 4 | ||
| Question about a 2 mass, multiple pulley problem. | Introductory Physics Homework | 8 | ||
