Thread Closed
How does someone become an Engineer?
Share Thread Thread Tools
Mar22-08, 05:28 PM   #1
Hi,
I believe I might be getting false info. As much as I love Math, Engineering might be right for me. I said let me post on a Ham Radio forum. Yes Ham Radio not Physics forums, not Math forums, no College forums but a Radio forum.
Here is the reply I have. I believe I don't need to be a PE to be an Engineer? Correct? If an Engineer of my chose I want and it's an undergraduate BS. I just make sure I have the classes the college wants to accept me.
Is this false info below?
Actually that is not true. In a lot of states you cannot sign a document as an "engineer" unless your a Professional Engineer (PE) in a number of fields to include electrical and structural. They are considered the best of the best and a number of them that I know have Ph.D's in their associated fields.
PhysOrg.com
PhysOrg
science news on PhysOrg.com
>> Heat-related deaths in Manhattan projected to rise
>> Dire outlook despite global warming 'pause': study
>> Sea level influenced tropical climate during the last ice age
Mar22-08, 05:35 PM   #2
Get your degree first. Then gain the necessary work experience requirements and write the exams for licensure. Once you have your PE, then you will be an engineer.
If you don't get a PE, you can still do engineering work, but any design work you do will have to be stamped by a PE be it your supervisor.
Mar22-08, 05:37 PM   #3
A PE is necessary for most engineering fields. Good to have for most the the rest. The one weird exception is software.
Mar22-08, 05:59 PM   #4
D H
Mentor
A PE is not necessary in aerospace engineering and some other branches of engineering as well. Wikipedia (http://en.wikipedia.org/wiki/Profess...ensed_practice) has this to say:
Quote by Wikipedia
Since regulation of the practice of engineering is performed by the individual states in the U.S., areas of engineering involved in interstate commerce are essentially unregulated. These areas include much of Mechanical Engineering, such as Automotive Engineering and Aerospace Engineering, and Chemical Engineering, and may be specifically exempted from regulation under an "Industrial Exemption". An industrial exemption covers engineers who design products such as automobiles that are sold (or have the potential to be sold) outside the state in which they are produced, as well as the equipment used to produce the product.
Mar22-08, 06:05 PM   #5
Admin
To sign off on drawing and specs, and perform certain engineering functions, one does need a PE license, and then one can append PE to one's name (legally that is).
To be an engineer one needs to have at least an undergraduate degree in the sciences or engineering from an accredited university/academic program, and then one can work as an engineer in a company that does engineering. Many companies have levels of engineer, e.g. junior, senior, principal, consulting, etc based on the level of experience.
If one wants to be an engineer then one should do a 4-yr undergrad program for BS, and probably 1-2 yrs for MS. One could go on and do a PhD program is there is a particular area of research in which one is interested.
Mar22-08, 06:18 PM   #6
Like Mutant engineering.
Mar22-08, 06:30 PM   #7
Recognitions:
Gold Membership Gold Member
Retired Staff Staff Emeritus
Quote by Astronuc View Post
To sign off on drawing and specs, and perform certain engineering functions, one does not a PE licence, and then one can append PE to one's name (legally that is).
I don't usually point out typos, but this one seems critical to understanding. Did you mean "one does need..." or did you mean "one does not need..."?
I presume you meant to say one needs the PE for those functions, but can work as an engineer without it, just someone with a PE needs to sign off on everything (and my impression is this is covered within most engineering firms by having senior staff with PEs who sign off on the more junior staff's work).
Mar22-08, 06:55 PM   #8
Mentor
Quote by wildman View Post
I would say a PE is necessary in few engineering fields and completely irrelevant in most of the rest. A PE enables you to seal permit drawings for approval by the government. So if what you do doesn't require that, you don't need a PE.
My father is a metallurgical engineer. He worked for Air Products and a German competitor, MG Industries. He knew or had working for him dozens of engineers over his career. Only one was a PE and he never considered getting one himself. It was just irrelevant.
Companies like Boeing and Exxon employ thousands of engineers. Few are likely to be PEs. And don't forget building engineers and manufacturing engineers. They don't get PEs either.
Mar22-08, 07:03 PM   #9
Ok. Does Nuclear Engineering requires a PE?
Quote by russ_watters View Post
Mar22-08, 07:15 PM   #10
Recognitions:
Quote by php111 View Post
It probably depends on what you plan to do with the degree.
Keep in mind that a PE is a licensing exam taken AFTER you have work experience (this is part of the requirements for taking the exam...I think it's 5 years experience, but I could be remembering wrong...I'm not an engineer, just associate with some of them). If you need it, you'll get the experience and study for it (there are prep courses to help people study for it if you need them). It's so far down the road that it's not worth worrying about. Before it ever becomes an issue, you need to get into an engineering school, graduate from engineering school, and get a job for a few years. If you manage all that, with some studying, you should be able to pass the PE exam if it's required for your job.
Mar22-08, 07:19 PM   #11
What I did was get a BS EE degree first. Then there were no circuit design jobs in the area where I wanted to live, so I accepted a job in a large company that had plenty of circuit design jobs, none of those departments hiring at the moment, but taking a position doing something else. Then I got myself a transfer to the division of the company that had the circuit design jobs, which still weren't hiring, and I was still doing a different kind of work, but now in the right division. Then they paid me to get my MS EE. In addition to paying the tuition they also made the grad school my full time job for a year, and I lived on an expense account for the year while my paychecks went right into savings. By then it was understood that I would return with a transfer to the product design group.
Mar22-08, 07:19 PM   #12
Admin
For certain functions at suppliers and utilities - yes, a PE is required. For most applications/jobs, a PE is not necessary.
Mar22-08, 08:47 PM   #13
Mentor
Maybe we should back up a little -- you haven't even started college yet. Why are you concerned about this issue? It isn't an issue you really need to even think about until you are ready to start your engineering career. When you pick your field, that will determine whether you need to have a PE (or if it is a good idea but not essential, or if it is completely unnecessary).
Mar23-08, 01:01 PM   #14
I agree with russ_watters, worry about getting your engineering degree first, worry about getting your PE later on. I am a second year mechanical engineering student, and have talked to engineers who have their PE, as well as engineers who don't have their PE. Both are engineers, the difference is that for some jobs (such as those involving design) you need a PE and for others you don't. It all depends on what you want to do with your engineering degree.
If you think you are interested in engineering, decide what type of engineering it is that you are interested in, find the schools that offer the program, and apply. It's not a one-chance decision that is going to determine the rest of your life, I know many people who have switched between different engineering disciplines (including myself after first year) as well as many people that have switched from engineering to other programs such as math, life sciences, law, general arts etc...
I guess what I'm trying to say is that you are getting too far ahead of yourself.
Mar23-08, 01:47 PM   #15
Recognitions:
Why would getting a PE be such a burden that you'd avoid an entire field anyway? The PE is really not that big of a deal.
(And Russ is right -- many engineering jobs, including my own, do not require a PE.)
- Warren
Mar23-08, 02:16 PM   #16
If you make sure your BS is ABET accredited, then you can always deal with this later. And, that accreditation almost guarantees a decent education even if you never consider a PE.
Mar23-08, 02:19 PM   #17
Admin
Quote by chroot View Post
- Warren
That's right - it's no big deal. I took the EIT/Fundamentals during my MS program. That's essentially like an SAT or GRE. To get a PE, all I need to do is sit for an 8 hr exam in the specialty for which I'd get the PE.
First get the BS in whatever discipline of interest.
Thread Closed
Thread Tools
Similar Threads for: How does someone become an Engineer?
Thread Forum Replies
What do you do as an engineer? General Engineering 8
Becoming an Engineer General Engineering 0
once an engineer, always an engineer. General Discussion 5
should i become an engineer? Academic Guidance 1
