| Thread Closed |
Step by Step rearranging with square roots... |
Share Thread | Thread Tools |
| Apr23-04, 10:18 PM | #1 |
Hello,
I have a simple equation (maybe simple for some) that I can't understand how to get from one point to the next when re-arranging. If you can help by giving an answer in english I would be thankful... The equation T = 2 pi square root L / g (sorry couldn't find the square root etc...) I want to solve for L So the answer will be L = g / T 4 pi^2 Why is that? How do I get from the first equation to solving for L. Can you please explain in simplistic terms that way I can see my errors. Thanks. Maybe you can tell me how to do the square root and pi symbols... |
| Apr23-04, 10:26 PM | #2 |
i don't know how to use LaTeX, so i can't make the equations loko nice:
:P Anyways (this the eq'n for the period of a simple pendulum?): T = 2pi * sqrt(L/g) Divide by 2pi on both sides: T / 2pi = sqrt(L/g) = [L/g]^(1/2) Square both sides (i.e. raise to the exponent 2): [T/2pi]^2 = [L/g]^{(1/2)(2)} Then multiply by g: L = g * [T/2pi]^2 I didn't get your L = g / T 4 pi^2 just checking over my work for any errors right now |
| Apr23-04, 10:34 PM | #3 |
Thanks for the reply... I got the same as you the first and the second time, but the book got something different....
| Apr23-04, 10:43 PM | #4 |
OK - I have looked through it and I can't get the same answer as the book...
The question is Calculate the length of cable required to give a clock (grandfather clock) a frequency of 1.0 Hz. So T = 2 pi * sq rt L / g They work the answer through as L = g / T 4 pi^2 = 9.8 / 4 pi^2 = 0.25 m (a reasonable answer, but how the hell do we get to it?) |
| Apr23-04, 10:45 PM | #5 |
DOH - I get it!!!
| Apr23-04, 10:47 PM | #6 |
But then in that case... that would mean EVERY grandfather clock has a pendulum with a cable length of 0.25 m - does that sound correct? Because the mass doesn't change the period, and the height it is dropped doesn't change the period so then only the lenght of the cable will change the period... Is this true?
| Apr24-04, 12:51 AM | #7 |
Recognitions:
| Apr24-04, 12:55 AM | #8 |
Recognitions:
| Thread Closed |
| Thread Tools | |
Similar Threads for: Step by Step rearranging with square roots...
| Math Help, solution step by step | Calculus & Beyond Homework | 3 | ||
| Differential Equation Problem_Solution step by step | Calculus & Beyond Homework | 1 | ||
| Math Help q2, solution step by step | Calculus & Beyond Homework | 1 | ||
| [SOLVED] How does my book get from this step to this step? | Calculus & Beyond Homework | 5 | ||
