Functions that integrate to a gamma function?
The discussion revolves around integrating a function of the form \( \theta^y \cdot e^{-\theta(1-\alpha)} \) to obtain a result involving the gamma function. Participants explore various approaches to manipulate the integral and match it to known forms of the gamma function or related functions.
  • David presents an integral involving \( \theta^y \cdot e^{-\theta(1-\alpha)} \) and seeks hints on how to manipulate it to yield a gamma function.
  • One participant suggests matching the integral to the generalized form of the gamma function or the exponential integral function, requesting clarification on the desired final form.
  • David expresses confusion about transforming \( t^\alpha \) to \( t^{\alpha - 1} \) and discusses the challenge of manipulating the integration variable.
  • Another participant mentions the recursive property of the gamma function, indicating it requires integration limits from 0 to infinity.
  • David reiterates the difficulty in matching the forms and suggests using integration by parts to differentiate \( t^\alpha \).
  • A later reply proposes a transformation of the variable \( \theta(1-\alpha) = u \) to relate the integral to the gamma function.
Participants express varying approaches to the problem, with no consensus on a single method or solution. The discussion remains unresolved as participants explore different techniques and transformations.
There are limitations in the assumptions regarding the integration limits and the specific forms of the functions being discussed, which may affect the applicability of the proposed methods.
daviddoria
maple syntax:
int(theta^y * exp(-theta*(1-alpha) ) , theta)
I have a distribution that I need to integrate, and I know the result should have a gamma function in it.
The only thing I have found helpful is:
http://en.wikipedia.org/wiki/Gamma_function
My function is kind of in that form (theta^something * exp(something) ), but the "somethings" don't seem to be able to be manipulated into that form. Any hints on how to go about this?
Thanks!
David
You could match it with this generalized form of the gamma function (sometimes called the Plica Function):
[tex]\Gamma (a,z)=\int_z^{\infty } t^{a-1} e^{-t} dt[/tex]
Or you could also match it with the exponential integral function (n is an integer):
[tex]E_n (z)=\int_1^{\infty } \frac{e^{-z t}}{t^n} dt[/tex]
If you must match it to a non-generalized gamma expression, show us the final form you are aiming for.
I don't understand how I would match it with those? The problem is I have
t^alpha
and I need
t^(alpha - 1)
The only way I would know to "mold" mine into the correct one is to multiply by t^(-1) and t, then take t outside the integral and combine t^alpha with t^(-1) to get t^(alpha-1). However, t is the integration variable, so I can't do that!
any other thoughts?
Thanks,
David
Use the recursive property of the gamma function:
[tex]\Gamma(\alpha+1) = \alpha \Gamma(\alpha)[/tex]
This does require, however, that your limits of integration are 0 to infinity.
t^alpha
and I need
t^(alpha - 1)
Use integration by parts, differentiate t^alpha.
If the integral you are looking for is the following (assuming the limits are correct):
[tex]\int_{0}^{\infty}\theta^y \cdot e^{-\theta(1-\alpha)} d\theta[/tex]
You can transform it using:
[tex]\theta(1-\alpha)=u[/tex]
This gives you something related to the Gamma function.
  • · Replies 16 ·
  • · Replies 16 ·
  • · Replies 200 ·
32K
