| Thread Closed |
Newtons law, interacting objects question?? |
Share Thread | Thread Tools |
| Mar23-08, 02:00 PM | #1 |
A block of mass 5.00 Kg sits on top of a second block of mass 15.0 Kg, which in
turn sits on a horizontal table. The coefficients of friction between the two blocks are : μs = 0.300 and μk = 0.100. The coefficients of friction between the lower block and the table surface are: μs = 0.500 and μk = 0.400. You apply a constant horizontal force to the lower block so that this force is just large enough to make this block start sliding out from between the upper block and the table. (a) Draw the free body diagram for each block, naming the forces on each of them. (b) Determine the magnitude of each force on each block at the instant you have started pushing but motion has not started. (c) Determine the acceleration you measure for each block. |
| Mar23-08, 02:18 PM | #2 |
Hi Xinio64! Welcome to PF!
![]() You must tell us how far you've got, so that we know what's troubling you, and how to help. What have you tried? have you drawn the diagram? What equations have you got?
| Mar23-08, 03:26 PM | #3 |
| Mar23-08, 06:06 PM | #4 |
Newtons law, interacting objects question??![]() To get the starting force, you must use the static coefficient. To get the movement, you use the kinetic coefficient (but of course you use the force you got from the static coefficient). So … what value force do you get, and how do you carry on from there?
| Thread Closed |
| Thread Tools | |
Similar Threads for: Newtons law, interacting objects question??
| Newtons Law Problem: objects and pulleys | Introductory Physics Homework | 1 | ||
| Why the black objects absorb more light and heat from the other color objects? | General Physics | 27 | ||
| Eigenstates of interacting and non-interacting Hamiltonian | General Physics | 1 | ||
| [Quick] States of interacting and non-interacting Hamiltonian | Quantum Physics | 5 | ||
| Newtons third law question. | General Physics | 4 | ||
