Topology: homeomorphism between quotient spaces
The discussion focuses on demonstrating the homeomorphism between the quotient spaces R², R²/D², R²/I, and R²/A, where D² is the closed ball of radius 1 centered at the origin, I is the closed interval [0,1], and A is a union of line segments with a common endpoint at the origin. The user presents a proof that R²/D² is homeomorphic to R²/I by defining a continuous, surjective map and discusses the complexity of their proof. They also inquire about the homeomorphism of quotient spaces under equivalence relations and seek feedback on their proof's elegance and correctness.
  • Understanding of quotient spaces in topology
  • Familiarity with homeomorphism and continuous functions
  • Knowledge of equivalence relations and their applications in topology
  • Basic concepts of R² and geometric transformations
  • Study the properties of quotient spaces in topology
  • Learn about continuous mappings and their role in establishing homeomorphisms
  • Investigate the concept of equivalence relations in mathematical contexts
  • Explore advanced examples of homeomorphic spaces and their implications
Mathematicians, particularly those specializing in topology, students studying advanced mathematics, and anyone interested in the properties of geometric spaces and homeomorphisms.
jjou
I posted this earlier and thought I solved it using a certain definition, which now I think is wrong, so I'm posting this again:
Show that the quotient spaces [tex]R^2, R^2/D^2, R^2/I,[/tex] and [tex]R^2/A[/tex] are homeomorphic where [tex]D^2[/tex] is the closed ball of radius 1, centered at the origin. [tex]I[/tex] is the closed interval [tex][0,1]\in\mathbb{R}[/tex]. [tex]A[/tex] is a union of line segments with a common endpoint (without loss of generality, we can assume the common endpoint is the origin and the first line segment is the interval [0,1] on the x-axis).
I showed that [tex]R^2[/tex] ~ [tex]R^2/D^2[/tex].
Showing [tex]R^2[/tex] ~ [tex]R^2/I[/tex]: We define [tex]R^2/I[/tex] by the equivalence relation [tex](x_1,0)[/tex] ~ [tex](x_2,0)[/tex] iff [tex]x_1,x_2\in[0,1][/tex]. I think it is enough to show that [tex]R^2/[-1,1][/tex] ~ [tex]R^2/D^2[/tex] since changing the interval shouldn't make a drastic difference (I could just rescale & recenter the original segment [tex]I[/tex]).
My proof of this is quite complicated (I think), so would somebody mind checking it / suggesting a more elegant proof? My proof is as follows:
It is enough to find a continuous, surjective map [tex]f:R^2/D^2\rightarrow R^2/[-1,1][/tex] to show the two spaces are homeomorphic. I define this function [tex]f[/tex] to send each point in [tex]D^2[/tex] to its projection on [-1,1]: [tex]f(r,\theta)=(r\cos\theta,0)[/tex] for [tex]r\leq1[/tex].
Then, for points outside of [tex]D^2[/tex], I consider the function [tex]r(\theta)=e^{\theta}[/tex] for [tex]0\leq\theta\leq\pi/2[/tex]. This defines a portion of a spiral-like curve starting at the point (1,0). I reflect this curve over the y-axis for [tex]\pi/2<\theta\leq\pi[/tex] and then reflect over the x-axis for [tex]\pi<\theta<2\pi[/tex].
For points outside of the "spiral," I define [tex]f(r,\theta)=(r\theta)[/tex] (it is the identity map). For points [tex](r,\theta)[/tex] where [tex]1<\theta\leq e^{\theta}[/tex] (i.e. for points outside of D^2 but within the spiral), I in essence "stretch" the segment [tex]((1,\theta),(e^{theta},\theta)][/tex] to cover [tex]((0,\theta),(e^{\theta},\theta)][/tex]. (The actual formulation of this stretching is a bit convoluted, but I have it.)
Then this map [tex]f[/tex] is clearly surjective. Furthermore, it is sequentially continuous (we only need to check the boundaries [tex]r=1[/tex] and [tex]r=e^{\theta}[/tex]). The only "fishy" points are [tex](1,0)[/tex] and [tex](\pi,0)[/tex], but it should work out.
Can anyone find anything wrong with this proof or suggest a simpler method? (I'm almost certain the solution should not be this complicated!)
PS: I think, to show that [tex]R^2/A[/tex] ~ [tex]R^2/I[/tex] can be done by induction and through a method similar to the one described above but with even more reflections - thus, an extremely ugly process.
Technical question:
If a set A is homeomorphic to another set B, is it true that the quotient space A/S is homeomorphic to the quotient space B/S (assuming the partition S makes sense for both sets A and B)?
Would really appreciate some feedback on this & the question above. Thanks. :)
