Power Series Solution to a Diff EQ
The discussion focuses on finding the first five terms of a power series solution for the differential equation y' + 2xy = 0. The solution involves assuming a power series form y = ∑(c_n * x^n) and manipulating the series to derive a recursion formula: c_{k+1} = -2c_{k-1} / (k+1). The user confirms that plugging in values for k from 1 to 9 generates sufficient coefficients to express the first five non-zero terms. Additionally, it is noted that an initial condition is necessary to define c_0, which serves as the integration constant.
  • Understanding of power series and their convergence
  • Familiarity with differential equations, specifically first-order linear ODEs
  • Knowledge of recursion relations and their applications
  • Basic calculus, including differentiation and series manipulation
  • Explore the derivation of power series solutions for other types of differential equations
  • Learn about the relationship between power series and exponential functions
  • Investigate initial value problems and their role in defining constants in series solutions
  • Study the convergence criteria for power series in the context of differential equations
Students and educators in mathematics, particularly those studying differential equations, as well as anyone interested in advanced calculus and series solutions.
Saladsamurai
[SOLVED] !Power Series Solution to a Diff EQ!
Find the first 5 term of a Power series solution of
[tex]y'+2xy=0[/tex] (1)
Missed this class, so please bear with my attempt here.
Assuming that y takes the form
[tex]y=\sum_{n=0}^{\infty}c_nx^n[/tex]
Then (1) can be written:
[tex]\sum_{n=1}^{\infty}nc_nx^{n-1}+2x\sum_{n=0}^{\infty}c_nx^n=0[/tex]
Re-written 'in phase' and with the same indices (in terms of k):
[tex]c_1+\sum_{k=1}^{\infty}(k+1)c_{k+1}x^k+\sum_{k=1}^{\infty}2c_{k-1}x^k=0[/tex]
[tex]\Rightarrow c_1+\sum_{k=1}^{\infty}[(k+1)c_{k+1}+2c_{k-1}]x^k=0[/tex]
Now invoking the identity property, I can say that all coefficients of powers of x are equal to zero (including [itex]c_1*x^0[/itex])
So I can write:
[itex]c_1=0[/itex] and
[tex]c_{k+1}=-\frac{2c_{k-1}}{k+1}[/tex]Now I am stuck (I know I am almost there though!)
Should I just start plugging in numbers for k=1,2,3,4,5 ? Will this generate enough 'recursiveness' to solve for the 1st five terms?
Is that the correct approach?
Thanks!
Don't worry guys, I got it. And for those who might make future use of this thread, my approach was correct. Solving
[tex] c_{k+1}=-\frac{2c_{k-1}}{k+1}[/tex]
For k=1,2...,9 generates enough coefficients to write out the first five nonzero terms of the solution by plugging them back into
[tex] y=\sum_{n=0}^{\infty}c_nx^n[/tex]
I think you need one more initial condition on your series (example [itex]y(0)=x_0[/itex]). You need to define [itex]c_0[/itex] (or you can just leave [itex]c_0[/itex] as the 'integration' constant of the ODE). However, the recursion formula becomes pretty obvious once you have that. If you can't see it right away, try plugging in a few values. Since [itex]c_1=0[/itex] what can we say about all the odd labelled coefficients? You should get something that looks like the series of an exponential function. In fact, the series will have a closed form solution if you can see how your answer relates to the exponential series.
  • · Replies 17 ·
  • · Replies 17 ·
