Why Does a Charged Particle in a Magnetic Field Perform Circular Motion?
The discussion centers around the motion of a charged particle in a magnetic field, specifically addressing the nature of the force acting on the particle and the type of motion it undergoes. The subject area involves concepts from electromagnetism and classical mechanics.
  • Conceptual clarification, Mathematical reasoning
  • The original poster poses questions regarding the direction of the force on a charged particle in a magnetic field, the nature of the motion (circular vs. elliptical), and the work done by the magnetic force. Some participants provide reasoning based on the properties of forces and motion, particularly emphasizing the conditions for uniform circular motion.
The discussion is actively exploring the implications of constant perpendicular forces on the motion of charged particles. Participants have raised questions about the nature of the motion and provided reasoning related to the mechanics involved, but there is no explicit consensus reached on the interpretations presented.
Participants are operating under the assumption that the magnetic field is uniform and that the charge is moving with constant velocity. The original poster has indicated knowledge of the answers but seeks clarification on specific aspects of the problem.
KLscilevothma
http://www.geocities.com/bridgestein/Bffield.jpg
(copy and paste the above address to your browser please)
In fact I know the answers of this problem, but I have a question.
Here's the question.
A charge +q moving with constant velocity v enters into a uniform magnetic field region as shown. The magnetic flux density is B.
a) What is the direction of the force F experienced by q?
b) What is the work done by F?
c) What kind of motion it is performing?
d) Express the radius of curvature r of the change in terms of B, v, m and q. Where m is the mass of the charge.
ans:
a) Direction of force is always perpendicular to the direction of q. The point charge will go upward.
From the part (d), I know it is performing circular motion and that the work done by F is 0 J!
d) r = mv/(Bq)
Why it is performing circular motion? Can't it be an elliptical motion?
When you have a constant magnitude force that is always perpendicular to the velocity, uniform circular motion is the only possible result. To show this, you can use Newton's second law for the radial component of the force (that is the only nonzero component in this problem):
ΣFr=qvxB=mar
where v=vi and B=-Bk. You would then solve the differential equation for the trajectory, using the initial conditions, to see that the path is necessarily circular.
Also, if the motion were elliptical, the acceleration would not be perpendicular to the motion and the magnetic field would therefore do work, which is contradictory to your (correct) answer to b).
Thanks Tom and Claude Bile
  • · Replies 31 ·
