Electricity and Magnetism on lines of charge
The discussion focuses on the electric field generated by two infinitely-long parallel lines of charge, one positively charged with a uniform charge density [lambda] and the other negatively charged with a uniform charge density -[lambda]. The lines are positioned at y=d/2 and y=-d/2 in the x-y plane, respectively. The electric field between the lines can be calculated using the principle of superposition, leading to a net electric field that is non-zero in the region between the lines. The user seeks clarification on how to approach the problem mathematically to prove their initial assumption regarding the charge distribution.
  • Understanding of electric fields generated by line charges
  • Familiarity with the principle of superposition in electrostatics
  • Knowledge of vector calculus and coordinate systems
  • Ability to apply Gauss's Law for electric fields
  • Study the derivation of the electric field due to an infinite line charge
  • Learn how to apply the principle of superposition to multiple charge distributions
  • Review Gauss's Law and its application to cylindrical symmetry
  • Explore the concept of electric field lines and their representation in two-dimensional charge configurations
Students of electromagnetism, physics educators, and anyone studying electrostatics, particularly in the context of line charges and electric fields.
goodam
Two infinitely-long lines of charge run parallel to the z-axis. One has a positive uniform charge per unit length, [lambda]>0, and goes through the x y plane at x=0, y=d/2. The other has a negative uniform charge per unit length, -[lambda], and goes through x=0, y=-d/2. Nothing changes with the z coordinate; the state of affairs in any plane parallel to the x y plane is the same in the x y plane.
This is where I need help.
My thought is the charge will be 0, but I cannot prove this without an equation or some work.
What is the question the problem is asking about?
  • · Replies 36 ·
  • · Replies 31 ·
