| Thread Closed |
[SOLVED] Connecting a known and unknown battery |
Share Thread |
| Mar24-08, 04:56 PM | #1 |
An unmarked battery has an unknown internal resistance. If the battery is connected to a fresh 5.60 V battery (negligible internal resistance) positive to positive and negative to negative, the current through the circuit is 10.0 mA. If the polarity of the unknown battery is reversed, the current increases to 25.0 mA. Determine the emf and internal resistance of the unknown battery. Assume that in each case the direction of the current is negative to positive within the 5.60 V battery. 2. Relevant equations 3. The attempt at a solution I tried making two equations using the loop rule for each setup. 5.6 - .01*r - e = 0 5.6 - .025*r + e = 0 e = 2.4 V r = 320 ohms Would that be right? The resistance looks a little too high to me. When it says the batteries are connected positive to positive, does that mean the batteries are connected in series in the circuit? |
| Mar24-08, 06:22 PM | #2 |
This has nothing to do with being in series, because the batteries will be in series no matter how you connect them. |
| Mar24-08, 07:14 PM | #3 |
All right, thanks kamerling!
| Thread Closed |
Similar discussions for: [SOLVED] Connecting a known and unknown battery
| [SOLVED] Finding the unknown resistor using only an ohmmeter | Introductory Physics Homework | 5 | ||
| [SOLVED] Finding unknown matrix a, when aB=C | Precalculus Mathematics Homework | 4 | ||
| [SOLVED] Average speed with an unknown distance | Introductory Physics Homework | 2 | ||
| [SOLVED] Re: Why isn't the mathematician Henri =?UNKNOWN?Q?Poincar=E9?= acknowledged | General Physics | 0 | ||
| Terminal Voltage of unknown battery | Introductory Physics Homework | 9 | ||
